New usser x10
Good morning,
I’m new to home assistant, the truth is that I’m flirting with what can be achieved. to do, but I think the learning curve is very high.
I have been with the domitoca since 2010, with X10 tengnology, with a cm11, and heyu with a frontend.
After that I went to DomoticZ, and I have come to you after some meeting with friends and I am delighted, I just need to finish understanding how to write the configuration correctly.
I have several configurations that give me errors and after reading and reading I have not managed to avazar
X10
  • platform: mochad
    devices:
    devices:
    • address: c5
This does not work for me, even though I do not get an error to write, but it does give me an error when loading the configuration.
Mon Sep 24 2018 08:49:18 GMT + 0200 (Central European Summer Time)
INFO: homeassistant.util.package: Attempting install of colorlog == 3.1.4
Testing configuration at / config
Failed config
switch.mochad:
- Invalid config for [switch.mochad]: expected to list for dictionary value @ data [‘devices’]. Got OrderedDict ([(‘devices’, [OrderedDict ([(‘address’, ‘c5’), (‘name’, ‘Persiana Peques’)])])]). (See?, Line?). Please check the docs at https://home-assistant.io/components/switch.mochad/
- platform: mochad
devices: [source /config/configuration.yaml:132]
devices: [source /config/configuration.yaml:133]
- address: c5
Successful config (partial)
switch.mochad:
Where can the error be?
thank you very much,
I’m also new here, coming from Domoticz. For now just seeing if this is my cup of tea (rather have coffee, btw). As @webtense writes, the learning curve seems to be high.
Have HA running now with the very basic, Hue, Chromecast and my mediaplayer.
Still want to add more, but how.
Also, can’t seem to find if the RFXcom.com transciever is able to work, nor KaKu (CoCo).
very good, the learning curve is very high, but I think the result is worthwhile
the much more important than Domoticz, even though DMZ is easier to configure.
If you need something in particular and I can help you, do not hesitate to send it to us privately and we’ll talk,
good luck
