Hi
this operation is possible only on android platforms in dev mod, are you in this case ?
on iphone it’s not possible except if it’s rooted
in both cases i was not able to get the key
Hi
git pull
./autogen.sh
make
sudo make install
Everyone having problems with videoP2Proxy please use github issues
To prevent spamming this forum I will not answer issues here as of the writing of this post.
Thanks worked perfectly
Can we use this with multiple cameras? I have around 10 I wish to add.
Yes, it should work. Just use different ports. You can even run multiple instances simultaneously with the same camera.
If you have any other Xiaomi camera than the gateway model I will appreciate if you test and report on GitHub issues.
How to we set the output buffer size?
OutPacketBuffer::maxSize
I installed it but no miiocli, shall I report this in github?
It works perfectly with the new aqara camera gateway(lumi.camera.aq1). One thing to note is, if the camera is in sleep mode there won’t be a video to play obviously
Great work, thank you.
I’ve also tested this with dafang 1080p(isa.camera.df3) and xiaomi mijia 1080p(mijia.camera.v1) and it doesn’t work, at least for me.
To get the keys, I used the nox android emulator. Then you have to use this version of mi home app.
Then you have to install the dependencies:
sudo apt-get install build-essential git python3 python3-dev autoconf automake libtool liblivemedia-dev libjson-c-dev
I also needed this one.
sudo pip install netifaces
Finally you can install the miio package with:
sudo pip3 install python-miio
You will also need ffmpeg for this to work. Install it with:
sudo apt-get install ffmpeg
Use this command to see that it works:
sudo mirobo discover --handshake 1
It’ll show the devices but with false keys.
In order to get the keys:
In your nox emulator after syncing the mihome app go to this folder with a root enabled explorer (it comes preinstalled)
/data/data/com.xiaomi.smarthome/databases/
From that folder grab the miio2.db
file.
Move that file to your raspberry pi. And then use this command on the folder you put the file:
miio-extract-tokens miio2.db
It’will show all the available tokens for every device.
You need to use this one:
Camera Hub
Model: lumi.camera.aq1
IP address: 192.168.xx.xx ->This is the camera
Token: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
MAC: xx:xx:xx:xx:xx:xx
After this install the videoP2Proxy program by:
git clone https://github.com/miguelangel-nubla/videoP2Proxy.git
cd videoP2Proxy
./autogen.sh
make
sudo make install
If everything went fine. Use this command to start the feed:
videop2proxy --ip 192.168.xx.xx --token xxxxxxxxxxxxxxxxxxxxx --rtsp 8554
192.168.xx.xx is the camera ip and the command starts a rtsp stream on your rpi with ip 192.168.yy.yy.
Check the feed with VLC from address rtsp://192.168.yy.yy:8554 Make sure the camera is not in sleep mode.
For the homeassistant part. Make a shell command in your configuration.yaml file:
shell_command:
camera_on: 'videop2proxy --ip 192.168.xx.xx --token xxxxxxxxxxxxxxxxxxxxxx --rtsp 8554'
Call this command when homeassistant starts:
- id: autoXX
alias: Start Scripts
hide_entity: false
platform: homeassistant
event: start
- service: shell_command.camera_on
And finally use this as a new camera entity:
camera:
- platform: ffmpeg
input: -rtsp_transport tcp -i rtsp://192.168.yy.yy:8554/
In order to stop the feed, I’ve opened an issue on videop2proxy github page. But from miio issues page I’ve found these commands and they work. This makes the camera sleep
miiocli device --ip 192.168.xx.xx --token xxxxxxxxxxxxxxxxxxxxxxxx raw_command set_video '["off"]'
This makes the sleep off
miiocli device --ip 192.168.xx.xx --token xxxxxxxxxxxxxxxxxxxxxxxx raw_command set_video '["on"]'
Use them like this:
shell_command:
camera_on: 'videop2proxy --ip 192.168.xx.xx --token 473055577175774b4369774835553044 --rtsp 8554'
camera_video_on: "miiocli device --ip 192.168.xx.xx --token 473055577175774b4369774835553044 raw_command set_video '[\"on\"]'"
camera_video_off: "miiocli device --ip 192.168.xx.xx --token 473055577175774b4369774835553044 raw_command set_video '[\"off\"]'"
thanks a lot, will test this night
Thanks for the info. Tried the procedure on my Macbook & RPi3-with-HA. I think i get all the steps up to finding the miio2.db (including a successful mirobo discover test and seeing my devices in the emulated Xiaomi app), but Nox on my Macbook does not give me the mentioned path/folder. I do find a “com.xiaomi.smarthome/” in /sdcard/Andriod/data/com.xiaomi.smarthome, but don’t find a databases, only a “cache” and “files”.
you have to enable “root” access mode in the file manager. go to settings, then change the access mode there. Then you’ll see all the items.
You mean start “ES File Explorer”, hamburger menu top left, scroll down, toggle option “Root Explorer”? I get a “Sorry, test failed. This feature cannot run on your device.”
No, you should use the built in “File Manager” app. I’ve also tried the es file explorer app at first, but as you mentioned couldn’t get it to work either.
I can’t find how to use the root option in that file manager
Open up the file manager app. Press the three dots on right bottom. That’s the settings. Choose general settings. Press the “Access mode”. Choose “Root access mode”. You should be able to see the files at that moment.
Access Mode is greyed out, stating “Safe mode - the app is running without priveleges ”. Clicking it does nothing for me, i’m not offered any choice to change it.
Just found a tiny grey-on-black ‘settings’ icon in the top right corner of Nox … having an option ‘Root’ in Off mode … switched it to On, Clicked Save, emulator rebooted > have the option now. Sorry, and thank you for the help… Will try to find time to proceed your procedure…
