Hi , I have the new Yeelight GU10 Bulbs and managed to add it to HA via integration.
However , no device/entities is created.
Any solutions?
Any solutions?
Same here.
Lan control is enabled.
Maybe has something to do with this ?
don’t think. Yeelight integration just don’t have this GU10 model on it.
Help please! actually i’ve got 6 bulbs of this …
Help with what exacly? You should either not have bought it as it’s not on the supported devices list or be patient untill it gets added.
I have succesfully added it via standart yeelight integration. Firstly i have added it to yeelight app and choosed local mode and after it yeelight integration in HA sucessfully found this bulb in local network.
I have yeelight gu10 smart bulb w1 (gu10 colour)
I have the same. A Color and a w1.
But it seems that HA can hold the connection.
It says it’s offline but in the yeelight app it’s still working. After a power cycle it’s working for a few minutes. I have nog problems with the color bulb
Hey all.
I also got this problem. GU10 color version is working fine, warm white version only works for some minutes after power cycle. Yeelight App works fine, so I guess it’s a HA related problem.
I’m running Home Assistant 2021.12.8. Is this issue fixed in HA2022.x ? Does anybody know?
,anyone found the root-cause of that issue , I am struggling the same problem
