I’m failing at searching this out, and I"m assuming I’m just not searching the right keywords?
But I have several Moe’s devices that have limited functionality in HA using ZHA. But the log book shows the keypresses coming in as what I would describe as “Scenes”.
Can I take that data from the log book and turn it into something actionable in an automation? Like screenshot attached, the on/off are exposed and work but that scene activation I’d like to use.
Is that a quirk? There is no configuration.yaml anymore so those articles are a dead end.
LOL, you can just say “you’re wrong” my ego can take it. I read the article about how each Zigbee device is in the configuration.yaml under zha: header, (which I don’t have nor is it in Sensors or switches.yaml)
I searched around that topic and found others mentioning it was moved out of configurations.yaml and recommended not to use the yaml for zha anymore but use quirks and scripts.
So if any of that is untrue, I followed the wrong rabbit.
I feel like I’m so close but I think I’m still missing something simple. So I DO want it to trigger regardless of level so I blanked out the data field, but its not triggering the automation. I’m assuming I’ve got things in the wrong fields and I"m missing how to connect the dots.
This fires in Logbook:
BedroomMoeClicker Move To Level event was fired with parameters: {‘level’: 63, ‘transition_time’: 1, ‘options_mask’: None, ‘options_override’: None}
But this Automation doesn’t work. Do I need something different in Type? I’ve tried mulitple combinations and the trigger never fires.
I found a workaround until I learn more or HA matures a bit by controlling the device with a different ecosystem outside of Home assistant. Just stinks I can’t centralize it.
If this is the same Moes button that I’ve got, it can be tripple clicked to switch between “remote mode” and “scene mode” (you DID read the manual that came with the button right?)
In “remote mode” you get the move to level / color temp / hue saturation events that aren’t very easy to work with in HA. In “scene mode” you get single/double/hold events that are trivial to work with just like any other zigbee button.
It took me a while to try this but no, tripple click is just a double click in the log. The log shows the same thing if i Single click before and after a triple click. I did find the instructions and I’m not seeing anything about changing scene mode however its very Tuya centric about scene mode so maybe the Tuya app would have told me that.
