I just received my new Zooz USB stick so I can start using zwave. I’m running on a Raspberry pi. Plugged in the stick, and loaded the ZWave integration. I go into the integration and bring up the configuration page, then click “Start Network”. Nothing happens. In the OZW log, I see the following:
2020-07-22 16:36:00.134 Always, OpenZwave Version 1.4.3469 Starting Up
2020-07-22 16:36:15.602 Info, Setting Up Provided Network Key for Secure Communications
2020-07-22 16:36:15.603 Info, mgr, Added driver for controller /dev/ttyAMA0
2020-07-22 16:36:15.603 Info, Opening controller /dev/ttyAMA0
2020-07-22 16:36:15.604 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2020-07-22 16:36:15.608 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2020-07-22 16:36:15.610 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-07-22 16:36:15.610 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-07-22 16:36:15.611 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-07-22 16:36:15.611 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-07-22 16:36:15.611 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-07-22 16:36:15.612 Detail,
2020-07-22 16:36:15.612 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-07-22 16:36:16.612 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
Any idea what I’m missing? It looks like it sees the device, but is timing out trying to communicate with it.
Thanks.
ETA: Nevermind I figured it out. When I first plugged the stick in, I only saw /dev/ttyAMA0 listed. Now, also see that there is a /dev/ttyACM0. I changed the zwave integration to use that, and now the network starts up as expected. Anyway, gonna leave this here in case anybody else runs into this.
