Hello - I am very new to HA, I am trying to have a Aeotec Multi 6 sensor to turn on and off a TP LInk light switch in my laundry room. I am using Node-Red and can’t figure it out. I have I have used a inject node to try to test, and it appears ok, but it still doesn’t work. The multi 6 sensor is on battery, I am using the burglar sensor.
Any ideas?
Thank you for your help!
Export is here:
"id": "e6872f22.e0424",
"type": "tab",
"label": "Flow 3",
"disabled": false,
"info": ""
"id": "13663af4.fedbe5",
"type": "server-state-changed",
"z": "e6872f22.e0424",
"name": "Laundry Motion Detection",
"server": "f677971a.d3eeb8",
"version": 1,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "sensor.aeon_labs_zw100_multisensor_6_burglar",
"entityidfiltertype": "substring",
"outputinitially": false,
"state_type": "str",
"haltifstate": "8",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 2,
"output_only_on_state_change": false,
"x": 170,
"y": 200,
"wires": [
"c6b5e1f0.071b1"
"info": "binary_sensor.motion_sensor_158d00036d5a35_garage_workbox"
"id": "4e7cb8c8.39f768",
"type": "stoptimer",
"duration": "10",
"units": "Minute",
"payloadtype": "num",
"payloadval": "0",
"name": "10 minutes til off",
"x": 640,
"y": 240,
"wires": [
"acc68be4.0b8808"
"id": "acc68be4.0b8808",
"type": "api-call-service",
"name": "Turn them off",
"version": 1,
"debugenabled": false,
"service_domain": "light",
"service": "turn_off",
"entityId": "switch.laundry_room_switch",
"data": "",
"dataType": "json",
"mergecontext": "",
"output_location": "payload",
"output_location_type": "msg",
"mustacheAltTags": false,
"x": 890,
"y": 240,
"wires": [
"6cd1e87e.c86808"
"id": "9d959afe.c21bb8",
"name": "No? Turn them on",
"version": 1,
"debugenabled": true,
"service": "turn_on",
"data": "",
"dataType": "json",
"mergecontext": "",
"x": 970,
"y": 180,
"wires": [
"6cd1e87e.c86808"
"id": "c6b5e1f0.071b1",
"type": "switch",
"name": "",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "on",
"vt": "str"
"t": "eq",
"v": "off",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 450,
"y": 200,
"wires": [
"4e7cb8c8.39f768",
"7704f658.d23cd8"
"4e7cb8c8.39f768"
"id": "7704f658.d23cd8",
"type": "api-current-state",
"name": "Are the lights already on?",
"version": 1,
"outputs": 2,
"halt_if": "on",
"override_topic": false,
"entity_id": "switch.laundry_room_switch",
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"blockInputOverrides": false,
"x": 670,
"y": 180,
"wires": [
"9d959afe.c21bb8"
"id": "7b4d0596.7d48bc",
"type": "comment",
"info": "",
"x": 170,
"y": 160,
"wires": [],
"icon": "node-red/bluetooth.png"
"id": "6cd1e87e.c86808",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"x": 840,
"y": 500,
"wires": []
"id": "f677971a.d3eeb8",
"type": "server",
"z": "",
"name": "Home Assistant",
"legacy": false,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true
