I’m a newbi to HASSio, but am a regular on Linux and system / networking stuff.
I have HASSio running on my Raspberry PI 3B+, with a 32 GB SD (fast) card as storage.
Lovelace is working, so is SSH access and a number of things.
I can login, I found the yaml config files, but where is the www folder I need to implement Floorplan?
Please be informed that if you want to reference to the www directory in your yaml configuration you have to do it like this: /local/
E.g. if you have a file test.jpg inside the www directory and want to use it in the floorplan you use it like this: /local/test.jpg
