Newbie - can't get switch.turn_on to work
I’m trying to get my first automation to work, with a couple of simple Raspberry Pi GPIO operations.
Here is my device configuration:
switch:
  - platform: rpi_gpio
    ports:
      25: GarageDoorRelay
binary_sensor:
    ports:
      24: GarageDoorSensor
I don’t see these showing up under “Developer tools->States->Current entities”. Does that mean there’s something wrong with the device configuration? The configuration validates successfully with no errors in the log.
To try and make something happen, I created a dummy automation. However, when I trigger it (manually), I get this error in the log: WARNING (MainThread) [homeassistant.core] Unable to find service switch/turn_on. Does that mean it’s a problem with my entity id?
automation:
  - alias: Open or Close garage door
      platform: numeric_state
      entity_id: sensor.random_sensor
      above: 10
      service: switch.turn_on
      entity_id: switch.GarageDoorRelay
Thanks!!
try:
  service: homeassistant.turn_on
I believe entity IDs are always expressed in lower case.
So I think it should be:
automation:
      above: 10
      entity_id: switch.garagedoorrelay
