Hey there !
I just received and launched Home Assistant Green.
I followed a tutorial to install Mosquitto and Zigbee2MQTT.
I use SkyConnect and flashed the latest firmware Zigbee (EZSP) 7.4.2.0 build 0.
First problem : in Home Assistant, when I try to see SkyConnect, it just says « unsupported_firmware ». I tried flashing it again : it goes fine apparently but the error stays the same.
Now, I had a working Zigbee2MQTT but with errors when starting. I deleted it and installed again.
Now, it won’t start at all with this error :
[2024-07-15 17:21:45] error: z2m: Error while starting zigbee-herdsman
[2024-07-15 17:21:45] error: z2m: Failed to start zigbee
[2024-07-15 17:21:45] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-07-15 17:21:45] error: z2m: Exiting...
[2024-07-15 17:21:45] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:889:19)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:2722:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:129:29)
at Zigbee.start (/app/lib/zigbee.ts:63:27)
at Controller.start (/app/lib/controller.ts:139:27)
at start (/app/index.js:154:5)
This is making me, like, super sad and frustrated. It’s supposed to be a “clean” install : those are just literally the first things I installed on this HA Green, and it’s already not working as intended.
I would immensely appreciate some help =)
Thank you good people.
Wild guess, but does your Z2M config for the skyconnect contain the following?
serial:
adapter: ezsp
If so, you need to change it to
serial:
adapter: ember
as per the installation docs . Ezsp stopped being used since 7.4.0
ghostivv
(ghost ivv)
July 18, 2024, 6:53am
3
HI newbie here and also having same problem with smlight slzb-07 with latest recommended fw (same as OP). Hope this is allowed to post here instead of creating a duplicate thread as the issues are related apart from mine is in minipc within proxmox.
anyway, the problem for me is I can’t find the path for usb.
Blockquote
lsusb: /devices/pci0000:00/0000:00:01.2/usb1
System - > hardware ->USB1
That’s not the correct device. You have probably not configured Proxmox correctly. Either fix that or use the SLZB in ethernet mode.
ghostivv
(ghost ivv)
July 18, 2024, 7:31am
5
fs10
August 19, 2024, 3:29pm
6
hi all,
I am in the same boat as Newbie and also very new to HASS.
HS green
Sky Connect
I was using ZHA and was ok but couldnt find some devices so tried with Zigbee2mqtt and can not make it work.
Started with ezsp and changed to ember it progress furher hitting a problem
Configuration:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
mqtt: {}
serial:
port: >-
/dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_42f713dbdc9ced118b3074faa7669f5d-if00-port0
adapter: ember
Log:
Starting Zigbee2MQTT without watchdog.
[2024-08-19 17:01:16] info: z2m: Logging to console, file (filename: log.log)
[2024-08-19 17:01:16] info: z2m: Starting Zigbee2MQTT version 1.39.1 (commit #unknown )
[2024-08-19 17:01:16] info: z2m: Starting zigbee-herdsman (0.55.3)
[2024-08-19 17:01:17] info: zh:ember: Using default stack config.
[2024-08-19 17:01:17] info: zh:ember: ======== Ember Adapter Starting ========
[2024-08-19 17:01:17] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-08-19 17:01:17] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-08-19 17:01:17] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-08-19 17:01:17] info: zh:ember:uart:ash: Serial port opened
[2024-08-19 17:01:17] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-08-19 17:01:18] info: zh:ember:uart:ash: ======== ASH connected ========
[2024-08-19 17:01:18] info: zh:ember:uart:ash: ======== ASH started ========
[2024-08-19 17:01:18] info: zh:ember:ezsp: ======== EZSP started ========
[2024-08-19 17:01:18] error: z2m: Error while starting zigbee-herdsman
[2024-08-19 17:01:18] error: z2m: Failed to start zigbee
[2024-08-19 17:01:18] error: z2m: Check Zigbee2MQTT fails to start | Zigbee2MQTT for possible solutions
[2024-08-19 17:01:18] error: z2m: Exiting…
[2024-08-19 17:01:19] error: z2m: Error: Adapter EZSP protocol version (9) is not supported by Host [13-14].
francisp
(Francis)
August 19, 2024, 4:17pm
7
The error says it all
You are running ember on unsupported firmware. Update the firmware to 7.4.x
fs10
August 21, 2024, 8:03pm
9
Hi Sky connect firmware updated.
Still not working
[2024-08-21 21:56:25] info: zh:ember:uart:ash: DATA frames : RX=43, TX=38
[2024-08-21 21:56:25] info: zh:ember:uart:ash: DATA bytes : RX=397, TX=404
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Retry frames: RX=3, TX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: ACK frames : RX=1, TX=42
[2024-08-21 21:56:25] info: zh:ember:uart:ash: NAK frames : RX=0, TX=1
[2024-08-21 21:56:25] info: zh:ember:uart:ash: nRdy frames : RX=0, TX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: CRC errors : RX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Comm errors : RX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Length < minimum: RX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Length > maximum: RX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Bad controls : RX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Bad lengths : RX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Bad ACK numbers : RX=5
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Out of buffers : RX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Retry dupes : RX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Out of sequence : RX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: ACK timeouts : RX=0
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Port closed.
[2024-08-21 21:56:25] info: zh:ember:uart:ash: ======== ASH stopped ========
[2024-08-21 21:56:25] info: zh:ember:ezsp: ======== EZSP stopped ========
[2024-08-21 21:56:25] info: zh:ember: ======== Ember Adapter Stopped ========
[2024-08-21 21:56:25] info: zh:ember: ======== Ember Adapter Starting ========
[2024-08-21 21:56:25] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-08-21 21:56:25] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-08-21 21:56:25] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-08-21 21:56:25] info: zh:ember:uart:ash: Serial port opened
[2024-08-21 21:56:25] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-08-21 21:56:28] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-08-21 21:56:28] info: zh:ember:uart:ash: ======== ASH starting ========
[2024-08-21 21:56:29] info: zh:ember:uart:ash: ======== ASH connected ========
[2024-08-21 21:56:29] info: zh:ember:uart:ash: ======== ASH started ========
[2024-08-21 21:56:29] info: zh:ember:ezsp: ======== EZSP started ========
[2024-08-21 21:56:30] error: zh:ember:uart:ash: Received frame with CRC error
[2024-08-21 21:56:33] error: zh:ember:uart:ash: Received frame with comm error
[2024-08-21 21:56:43] error: zh:ember:ezsp: ERROR Transaction failure; status=ASH_ERROR_TIMEOUTS. Last Frame: [FRAME: ID=0:"VERSION" Seq=0 Len=0].
[2024-08-21 21:56:43] error: zh:ember: !!! ADAPTER FATAL ERROR reason=ASH_ERROR_TIMEOUTS. !!!
[2024-08-21 21:56:43] info: zh:ember: Attempting adapter reset...
[2024-08-21 21:56:43] info: zh:ember:uart:ash: ASH COUNTERS since last clear:
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Total frames: RX=5, TX=3
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Cancelled : RX=0, TX=0
[2024-08-21 21:56:43] info: zh:ember:uart:ash: DATA frames : RX=2, TX=1
[2024-08-21 21:56:43] info: zh:ember:uart:ash: DATA bytes : RX=0, TX=4
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Retry frames: RX=0, TX=0
[2024-08-21 21:56:43] info: zh:ember:uart:ash: ACK frames : RX=1, TX=0
[2024-08-21 21:56:43] info: zh:ember:uart:ash: NAK frames : RX=1, TX=1
[2024-08-21 21:56:43] info: zh:ember:uart:ash: nRdy frames : RX=0, TX=0
[2024-08-21 21:56:43] info: zh:ember:uart:ash: CRC errors : RX=1
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Comm errors : RX=1
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Length < minimum: RX=0
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Length > maximum: RX=0
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Bad controls : RX=0
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Bad lengths : RX=0
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Bad ACK numbers : RX=3
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Out of buffers : RX=0
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Retry dupes : RX=0
[2024-08-21 21:56:43] info: zh:ember:uart:ash: Out of sequence : RX=0
[2024-08-21 21:56:43] info: zh:ember:uart:ash: ACK timeouts : RX=0
[2024-08-21 21:56:43] error: zh:ember: Failed to reset and init adapter. Error: ASH_ERROR_TIMEOUTS
[2024-08-21 21:56:43] error: zh:ember:uart:ash: Failed to close serial port Error: Port is not open.
[2024-08-21 21:56:43] info: zh:ember:uart:ash: ======== ASH stopped ========
[2024-08-21 21:56:43] info: zh:ember:ezsp: ======== EZSP stopped ========
[2024-08-21 21:56:43] info: zh:ember: ======== Ember Adapter Stopped ========
[2024-08-21 21:56:43] error: z2m: Adapter disconnected, stopping
[2024-08-21 21:56:43] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"offline"}'
[2024-08-21 21:56:43] info: z2m: Disconnecting from MQTT server
[2024-08-21 21:56:43] info: z2m: Stopping zigbee-herdsman...
[2024-08-21 21:56:43] info: z2m: Stopped zigbee-herdsman
[2024-08-21 21:56:43] info: z2m: Stopped Zigbee2MQTT
/app/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264
var er = new ERR_STREAM_WRITE_AFTER_END();
Error: write after end
at writeAfterEnd (/app/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264:12)
at DerivedLogger.Writable.write (/app/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:300:21)
at DerivedLogger.log (/app/node_modules/winston/lib/winston/logger.js:231:12)
at Logger.log (/app/lib/util/logger.ts:189:25)
at Logger.error (/app/lib/util/logger.ts:194:14)
at EmberAdapter.onNcpNeedsResetAndInit (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1354:24)
[21:58:14] INFO: Preparing to start...
[21:58:15] INFO: Socat not enabled
francisp
(Francis)
August 22, 2024, 2:44am
10
Are you sure ZHA is not running ?
fs10
August 22, 2024, 1:39pm
11
Thanks Francsip. No I am not. I am very new so not sure of much. I disable ZHA (or at least I think I did) before starting the Zigbee2MQTT.
After the ZBMQQ failed to start I had to enable ZHA to make it work.
But I will retry disabelling the ZHA again just in case
fs10
September 4, 2024, 8:21am
12
Thanks Francisp. ZigbedtoMQQT wroking now.
