(Newbie) Fresh installation - cannot install add-ons
(Newbie here)
Hey there,
I just installed a fresh HA environment on a Raspberry Pi 4, following the official guide.
At first I wanted to access the underlying Linux OS but when connecting a monitor and a keyboard to the Pi, I only have access to the Home Assistant CLI which I cannot exit.
So after some research it looks like I could do this remotely with the SSH & Web Terminal addon, but when I click on the button to install it, I get the following message
This redirect is not supported by your Home Assistant installation. It needs either the Home Assistant Operating System or Home Assistant Supervised installation method.
Since I took the official Raspberry Pi image, isnā€™t it Home Assistant Operating System? I donā€™t get it.
Thanks,
Ben
which installation method have you choosen on that linked guide?
As far as I can see, it provides installation steps for ALL methods (OS, Docker, Core, ā€¦)
If you go to your HomeAssistant frontend and then to the ā€œAboutā€ page, you should get more informationā€¦
For HA OS it should look similar to this:
Well, I just followed the Installation guide by clicking on ā€œRaspberry Piā€ here, which leads you to the Raspberry Pi installation manual, and then, when you reach Get the URL for your Raspberry Pi - you have only 1 choice.
Hereā€™s what I get from the About page (looks exactly the same):
  1. Go to Settings > Add-ons
  2. Click the Add-on Store button
Back to basics.
You have been here http://homeassistant.local:8123 and setup an account and the basics of HA, havenā€™t you?. If not it wont work.
Looks like the default raspberry pi installation is sort of locked for that kind of operations.
I formatted and installed Raspbian + HA Docker, and everything works now.
Thanks!
Ben
Hello again,
A few months laterā€¦ I still get that silly message, which is very frustrating.
There is no (longer?) a setting ā†’ add-ons menu. Whenever I click on a repository link ā€œadd-on storeā€, I get that message:
This is particularly annoying. How am I supposed to proceed?
HA is running on an Rpi4 with Raspbian and Home Assistant Docker.
Thanks,
Ben
Install HA OS ? Be sure to make a backup first.
Thatā€™s what I did at the very first beginning, but I didnā€™t figure out how to access to the underlying Linux to add some other stuff alongside HA (esp. Caddy to expose HA through HTTPS) - so I switched to the Docker-based installation.
Looks like my only remaining option is the ā€œSupervised HAā€ using the supervised installer, I will look into this.
Thanks!
Ben
There is a caddy add-on for HA OS
