I just installed a fresh HA environment on a Raspberry Pi 4, following the official guide.
At first I wanted to access the underlying Linux OS but when connecting a monitor and a keyboard to the Pi, I only have access to the Home Assistant CLI which I cannot exit.
So after some research it looks like I could do this remotely with the SSH & Web Terminal addon, but when I click on the button to install it, I get the following message
This redirect is not supported by your Home Assistant installation. It needs either the Home Assistant Operating System or Home Assistant Supervised installation method.
Since I took the official Raspberry Pi image, isn’t it Home Assistant Operating System? I don’t get it.
which installation method have you choosen on that linked guide?
As far as I can see, it provides installation steps for ALL methods (OS, Docker, Core, …)
If you go to your HomeAssistant frontend and then to the “About” page, you should get more information…
For HA OS it should look similar to this:
Well, I just followed the Installation guide by clicking on “Raspberry Pi”here, which leads you to the Raspberry Pi installation manual, and then, when you reach Get the URL for your Raspberry Pi - you have only 1 choice.
Here’s what I get from the About page (looks exactly the same):
Looks like the default raspberry pi installation is sort of locked for that kind of operations.
I formatted and installed Raspbian + HA Docker, and everything works now.
A few months later… I still get that silly message, which is very frustrating.
There is no (longer?) a setting → add-ons menu. Whenever I click on a repository link “add-on store”, I get that message:
This is particularly annoying. How am I supposed to proceed?
HA is running on an Rpi4 with Raspbian and Home Assistant Docker.
That’s what I did at the very first beginning, but I didn’t figure out how to access to the underlying Linux to add some other stuff alongside HA (esp. Caddy to expose HA through HTTPS) - so I switched to the Docker-based installation.
Looks like my only remaining option is the “Supervised HA” using the supervised installer, I will look into this.
Thanks!
Ben
