Newbie here, please tell me which matter or thread addon i should install and how to configure everything
I have rpi 4b with homeassistant haos directly installed on sd card.
To usb i have connected Nabu Casa 522202 SkyConnect Silabs EFR32MG21
Now question one:
in devices configuration should I enable multiprotocol or not?
I enabled it, should i disable it?
question 2:
i would like to connect everything what i have to control evertyhing.
philips hue with bridge and dimmer switch, aqara g3 camera, aqara power plugs, buttons, cube.
I want for example:
depending how much i turn aqara cube in my hand so much hue bulb will increase light.
so light intensity depends on aqara cuble angle.
Also I want aqara buttons to control aqara smart plugs but also i want to be able to create such config:
when i press 2 buttons on hue dimmer switch philips i can also turn on or off aqara plug.
So i can control totally everything in howerever way i want, depending on weather, aqara humidity or temp sensors.
It would be also great to use automations I already have in camera hub g3, so camera detects movement something in home assistants happens.
Is this all possible?
Hue philips have matter, aqara hub g3 also have matter in settings, so how to connect all of that?
I also have aara presense sensor mmwave radar but for chinese region, so i cant connect it to my g3 eu, I would like to connect it to HA.
Also I want to connect ZY-M100-2W tuya presence sensor,
nuki door lock with bridge,
and power strip LDNIO SEW3452 3 AC Outlets Wi-Fi Smart Power Strip manufacturer/ 3 AC Outlets Wi-Fi Smart Power Strip supplier SEW3452 - LDNIO
please guide me, thanks.
Also one more question: if i have internet from isp who can not open port and i hae dynamic ip address, only way to remote control is through zero tier or vpn?
Mostly, yes. You may not be able to use the automations in the camera, that depends on what it exposes to HA.
Use the native Hue integration for Hue, not Matter. Matter is very limited compared to the native integration.
For your Zigbee devices I’d suggest ZHA or Zigbee2MQTT and your choice of Zigbee coordinator. You’ll get a far better experience than using any hub. That’ll allow you to easily include that Tuya sensor.
There’s native support for this, plus third party options.
You may be out of luck there unless it’s Tuya
Or Cloudflare Tunnels (free) with your own domain, or the Nabu Casa cloud service (paid).
Thanks, but I dont fully understand this line, zigbee coordinator is my usb nabu casa skyconnect?
Should i enable or disable multiprotocol on it?
also this power strip is tuya controlled as description says.
I also have one more question, can i use more than one connection to devices?
For example, can i have aqara plug conected to both: aqara g3 camera hub and to home assistant?
So if home assistant will fail i can still control it from aqara ?
or maybe all devices can be connected to only one gateway/hub?
is there any way to do failover?
Yes.
Thats up to you, but thats how you would access Matter over Thread devices. I agree with Tinkerer about connecting to Hue with Matter, so if you do it, do it because you have other matter devices to connect.
Depends on the device and connection. But generally assume one connection and it’s reshared from there. The Matter multinadmin features change that for matter devices but it’s not universal. Your mitigation is solid planning and restore process.
Yes
Probably not :wink:
For Zigbee no. For Matter it’s more complicated, but Matter (and Thread) is still very much a moving target.
