I am newbie - and the localisation is driving me crazy (2 days)
My Problem: I have a Markdown Card like this:
{{ states.sensor.todo_date_next.attributes | first | as_timestamp | timestamp_custom("%A, %d.%m.%Y") }}
So far i have the output: TODO Thursday, 07.04.2022
It works fine - but i want to localize the thursday, that is generated by timestamp_custom("%A
What i found was a hint:
{% set days = [“Montag”, “Dienstag”, “Mittwoch”, “Donnestag”, “Freitag”, “Samstag”, “Sonntag”] %}
but i tried every position with no effect.
Isn’t there a general “thing” where i can change this forever - to all weekdays?
And if no … where do i put this set days, so that it will work only for that output …
I found many explantions on putting a so called template sensor in configuration.yaml - but that didn’t have an effect. I think because it’s not somehow binded to the output above?
It’s really driving me crazy
Thank you drew . You made my day.
It’s a pitty that there is no general way. In pyhton you only need to import locale and call locale.setlocale () … But however … i will not use that DayofWeek very often, so i can write it in the code. Thanks again and have a nice week.
