I am trying to get Putty or something working so I can access folders on Home assistant from my windows machine.
I have DuckDNS set up and running and I can access the frontend, However I would like to add some of the custom UI cards and I cannot seem to get the FTP or Putty connection to work I installed this back in April, then is sat for a while and I just started to look at it more and would like to get that last piece setup…
thanks
Yes I assume if I see ‘Supervisor’ on the left and I am able to install add-ons, I am using the supervisor version. I have installed SSH & Web terminal , with no luck connecting.
Supervisor version is 247 and Host is HassOS 4.14
to access I am using duckdns and the only way to access the UI is https://subdomain.duckdns.org:8123 ( I need to the 8123 for both the IP or hostname
Here is the newbie question, how do I install openssh-server on the machine?
Just noticed a double backslash is a format code here… it should be:
\\192.168.0.x
It should then ask for credentials , you can use your HA username/password
