Hi
I am sorry, a bit lost here. Coming over from ZWave and Fibaro HC2 where I found a plugin that did this. Here, it looks like I have to write it, but I am a bit lost about how to start.
Basically I want an automation or script (confused) that when:
-the house is occupied (helper reading the alarm system)
-the living room is occupied (reading a switch)
then, depending on the time of day (night or day or dusk) and if its a weekday or not, sets about 4 lights in several states. Maybe have one for watching a movie, etc.
I tried to use the blueprint Smart Lights, and maybe it is good, but it cannot seem to handle different situations like this, and can only control one light.
I tried to make an automation, and I can setup on of these situations, but then I have to make one for each of them (day, night, dusk, etc). So I tried to open it in YAML mode and add several automations in one yaml file, but that didnt work out.
Should I approach this as a scene? or somehow write an automation that can have several states and several outputs?
