I have installed HA onto an Intel NUC (flashed to SSD, not VM).
I am really happy with it so far in so far that I have it bridging ZigBee devices to my existing HomeKit set-up. Fortunately, this gives me remote access to trigger geo-automations and manually control everything (but not to administer HA of course).
My one remaining issue is that it cannot reach past my local network. The System Information shows:
## System Information
version | core-2023.8.2
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.11.4
os_name | Linux
os_version | 6.1.39
arch | x86_64
timezone | Europe/London
config_dir | /config
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | failed to load: unreachable
can_reach_cloud_auth | failed to load: unreachable
can_reach_cloud | failed to load: unreachable
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 10.4
update_channel | stable
supervisor_version | supervisor-2023.08.1
agent_version | 1.5.1
docker_version | 23.0.6
disk_total | 234.0 GB
disk_used | 6.5 GB
healthy | true
supported | true
board | generic-x86-64
supervisor_api | ok
version_api | failed to load: unreachable
installed_addons | Studio Code Server (5.10.0), File editor (5.6.0), Terminal & SSH (9.7.1)
</details>
<details><summary>Dashboards</summary>
dashboards | 2
resources | 0
views | 1
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | 5 August 2023 at 17:06
current_recorder_run | 12 August 2023 at 11:18
estimated_db_size | 6.94 MiB
database_engine | sqlite
database_version | 3.41.2
</details>
Some things I’ve tried, none of which have worked:
Static IPv4
Disabled IPv6
Different router
Wired direct to router
My ISP set up is PPPoE. I have no other internet access issues from other network devices.
I can ping IPs from the HA terminal shell, but not domain names.
for sure you have a dns issue, as it can reach 8.8.8.8, but is unable to resolve google.com….
Tried changing your dns from 1.1.1.1 to your isp’s (or 8.8.8.8)??
