Pichuco
(Peter Weiss)
1
tried several ways to get this tasmota smartmeter reader integrated in HA:
- Hardware successfully configured and integrated in local Wifi
- Mosqitto MQTT Broker successfully setup and tasmota sensor found
- No values are displayed
- Current snippet in configuration.yaml:
mqtt:
- name: "Energy value"
state_topic: "tasmota/discovery/CC50E3F45EBB/sensors"
value_template: '{{ value_json["Power_curr"]["Today"] }}'
unit_of_measurement: "kWh"
device_class: energy
state_class: measurement
“Power_curr” is the name of the field exposed by the MQTT Explorer.
Checking the entity list this shows up with name “Energy Value”, entity sensor.energy_value, integration type sensor.
I’m able to add this entity to the energy dashboard, but no value shows up. Error message is “statistics_not_defined” and “entity not available”
How may I proceed here?
Any help is greatly appreciated.
Peter
Pichuco
(Peter Weiss)
2
The MQTT Explorer shows:
“sn”: {
“Time”: “2024-01-04T08:27:12”,
“SML”: {
“Total_in”: 565,
“Total_out”: 0,
“Power_curr”: 1900,
“Curr_summ”: 8.505,
“Volt_avg”: 229.453,
“Power_p1”: 1518,
“Power_p2”: 248,
“Power_p3”: 134,
“Curr_p1”: 6.767,
“Curr_p2”: 1.116,
“Curr_p3”: 0.622,
“Volt_p1”: 227.87,
“Volt_p2”: 231.33,
“Volt_p3”: 229.16,
“phase_angle_L2_L1”: 241,
“phase_angle_L3_L1”: 121,
“phase_angle_L1”: 352.7,
“phase_angle_L2”: 13.2,
“phase_angle_L3”: 340.6,
“Freq”: 50.1
“ver”: 1
How do I set the value of “Power_curr” for the entity?
marek76
(marek)
3
value_template: '{{ value_json.Power_curr }}'
if you just want to read the value as a sensor
state_topic: 'tasmota/discovery/CC50E3F45EBB/sensors'
state_template: '{{ value_json.phase_angle_L2_L1 }}'
for write must be defined as number
command_topic: 'tasmota/discovery/CC50E3F45EBB/sensors'
command_template: '{"phase_angle_L2_L1": {{ value }} }'
