Hi. I’m trying to make rflink work with HASSIO on a raspberry pi 3 with no progress. I think I installed the software on the arduino as you should as HASSIO can see 433 mhz units in my vicinity but I cant control it from HASS, the 433 switch I want to add comes up under
`light:
- platform: rflink`
and not under
`switch:
- platform: rflink`
But I saw a community post that it happens sometimes but it doesn’t matter. But what am I missing to control the switches from HASSIO… Feel free to ask me anything you think i left out and I’m just gonna paste in my entire configuration.yaml here
switch:
- platform: rflink
automatic_add: true
light:
- platform: rflink
automatic_add: true
# Weather prediction
- platform: yr
- platform: rflink
automatic_add: false
# Text to speech
tts:
- platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
logger:
default: error
logs:
rflink: debug
homeassistant.components.rflink: debug
rflink:
port: /dev/ttyACM0
reconnect_interval: 60
switch:
- platform: command_line
switches:
aeotec_zstick_disco_light:
friendly_name: 'Aeotec Z-Stick Disco Light'
command_on: 'echo -e -n "\x01\x08\x00\xF2\x51\x01\x01\x05\x01\x50" > /dev/serial/by-id/usb-0658_0200-if00'
command_off: 'echo -e -n "\x01\x08\x00\xF2\x51\x01\x00\x05\x01\x51" > /dev/serial/by-id/usb-0658_0200-if00'
zwave:
usb_path: /dev/ttyACM1
when using the controller that came with the switch i get two units that reacts in the HASSIO interface its a “newkaku_00156000_2” and “unitec_8550_01” both goes on when I press ON on the controll and both get off when I press OFF on the control, but when I press on/off in HASSIO nothing happens
