Newbie needs help with TasmoAdmin
I’m running “Hassbian” on a pi4 and want to install the “TasmoAdmin”. If someone can point me in the right direction I would appreciate it. I tried THIS method but getting stuck on “install tasmoadmin”. On the pi I get an error message - sudo: docker: command not found.
Thanks in advance
You need to install docker first :wink:
Google found me this guide.
I have a docker file on it. If I ran “ls” on the pi it shows a docker file and inside the docker file I have another file called “TasmAdmin” and inside it is a “Data” file. If I ran “sudo apt-get update” I get an error message:“E: Repository ‘http://raspbian.raspberrypi.org/raspbian buster InRelease’ changed its ‘Suite’ value from ‘testing’ to ‘stable’
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.”
Got the error sorted:clap:
