Newbie here. My final goal would be to control multiple devices at home. The first one would be my Gree A/C. I use an Ubuntu 18.04.5 LTS on my old laptop as a server. So I tried the easiest way and kicked off a docker image with the command:
sudo docker run --restart always -d --name homeassistant -v /opt/homeassistant:/config -e TZ=Europe/Budapest --net=host ghcr.io/home-assistant/home-assistant:latest
I can login and integrate my chromecast so the network is visible. Then i tried to use the Gree Climate integration but got the No Device Found error message. So i changed the config to see more in the logs but not much to see.
home-assistant.log:2021-07-06 17:28:34 INFO (MainThread) [greeclimate.discovery] Scanning for Gree devices ...
home-assistant.log:2021-07-06 17:28:34 DEBUG (MainThread) [greeclimate.discovery] Listening for devices on 192.168.50.120
home-assistant.log:2021-07-06 17:28:34 DEBUG (MainThread) [greeclimate.discovery] Listening for devices on 172.18.0.1
home-assistant.log:2021-07-06 17:28:34 DEBUG (MainThread) [greeclimate.discovery] Listening for devices on 172.17.0.1
So it checked the server’s IP then nothing. The climate is connected to my network it is visible in my router. Maybe I have to define the A/C’s IP somewhere? Or i have to do something totally different?
Please help I think i made a wrong turn somewhere
