dowermyr
(Dowermyr)
August 8, 2020, 11:05am
1
Installed HACS to install integrations from GitHub. Got the installed and can se them in HACS. But how do I start them som I can use them in for example Lovelace?
tom_l
August 8, 2020, 11:41am
2
You read the usage instructions on the integration’s github page and follow them.
dowermyr
(Dowermyr)
August 8, 2020, 11:56am
3
It just says install with HACS. Nothing more
francisp
(Francis)
August 8, 2020, 11:58am
4
Now you make me curious. What integration just says ‘install with hacs’?
tom_l
August 8, 2020, 12:20pm
6
There’s some how-to here:
Hi all,
this is my first integration for Homeassistant
and the first time, i code python at all.
This integration not only shows the same values as the well-known /api/v1/status rest templates,
it also shows voltage, amps, watts for all the phases as well as the current net-frequency and more.
i published the required lib to pypi, so it should just run after installing
to install, you use the integrations page wich asks you for the IP of your Sonnenbatterie and the password for the user …
