Newbie Pi 3B+ Installation Problem
Just tried installing (via manual install instructions at https://www.home-assistant.io/docs/installation/raspberry-pi/.
After entering pip3 install homeassistant, I get an exception very quickly after Collecting astra1==1.6.1 (from homeassistant).
Tried removing the venv and reinstalling… same problem. I’m just learning Python, so I don’t know too much more.
Any help would be greatly appreciated.
Attached is the terminal output from the install commands (starting with wheel):
Remote End closed connection without a response means pretty much what it says. There is some kind of network problem. Somebody else was experiencing this a few days ago, so it could be the server is having some capacity issues. See
Just hacking at the problem, i just did a pip install homeassistant instead of pip3. Seems to be working.
Now if I can just get my automation.yaml file set up properly :grimacing:
So, I see the problem is the documentation which says to use the command:
pip3 install home-assistant
But, it should be:
python3 -m pip install home-assistant
I recommended a change to the documentation
Homeseer??
Oops. Should obviously be home-assistant. So much for predictive input and 25 years of using Homseer. :upside_down_face:
