Hi everyone , i am a new hassio user. i have been playing with an idea i have had for weeks now and just cant get it to work the way i want it to.
i am trying to make a sensor or switch that will be turned into the on state when my entity: sensor.starter_battery is above 14 volts, i have tried with automation , and with this config,
.yaml setup , i just cant seem to get it to do what i want.
so i need to create a switch or entity , that i can switch on or off according to the voltage on my starter battery , ie if volts > 14 , then turn on battery is charging switch.
not sure if its the sensor /switch i am making is wrong , or the actual config is not running.
if anyone can please help me . done loads of reading before i headed here, jsut cant seem to get it :|(
here is one of my efforts is config.yaml
i also tried automation to use the service: homeassistant turn on, and switch turn on with no joy
i tried that Pippyn didnt seem to work for me , i now get a new entity in states [binary_sensor.starter_batt] but stays in an off postion even when my voltage is above the 14 as in your example
yes it should create another sensor.
The template i described should have worked. Can you test what the output is in the template editor in the dev tools when you test this: {{ states(sensor.starter_battery)|float }}
that means that sensor.starter_battery doesn’t exists. I assumed you had a sensor that reported the voltage in HA with the name sensor.starter_battery (as you describe in the first post). Can you check the name of the sensor and replace it in the template?
