Newbie question: How to start starting programming python in hassio
Hi guys, I’m just starting with hassio on my RPi; I have almost setup all my KNX devices and defined some custom automations.
I want to make a mod in climate/generic_thermostat.py; but I don’t know how to start.
I mean; where can I put generic_thermostat_mod.py to start developing? How to load it?
Maybe someone can point me to some documentation?
Thanks in advance.
Thanks.
The point is that I’m working with the hassio image on RPi. I don’t know much about docker; I know it’s a lightway container.
It’s possible to log through SSH and start adding/modifying python files?
Thanks.
The rest should be in the dev docs.
Hi silvrr; I have the ssh addon installed and running.
After logging throug ssh, I don’t know how to expose the docker container? to edit the source python files.
I think youre looking for custom component where you can edit your code in your config folder/custom_components
The code you will find on github
Thank you very much. Placing files inside custom_components will do the trick.
Going to code!!
