Hi, this is my first post so please be gentle! Also let me know if i’ve posted in the wrong place.
I’m running Core2023.12.4 with Frontend20231208.2 on a windows PC and I have a few simple integrations running nicely and so far I’m pretty pleased with myself as I’ve virtually no programming skills.
I found an integration on github for my Renac solar inverter (which isn’t listed within HACS) which I imported using HACS custom repositories and the github URL and it now appears in HACS.
The readme file says:
Place the custom_components folder in your configuration directory
which I do (the folder name is renac);and
Add to your Home-Assistant config:
renac:
username: <username>
password: <password>
equipment_serial: <inverter serial number>
which I also do, using quotes for each of the 3 values (and being mindful of the indents).
I have a couple of questions :
- Is it a good idea to be adding lines to the config file like this, and
- What could I be missing/doing wrong/misunderstanding because when I restart HA the following error log is generated:
Log Details (ERROR)
Logger: homeassistant.components.sensor
Source: C:\Users\Paul\Desktop\Home Assistant stuff\HassWP_2023.12.4\python-3.11.6.amd64\Lib\site-packages\homeassistant\helpers\entity_platform.py:419
Integration: Sensor (documentation, issues)
First occurred: 22 January 2024 at 8:57:26 pm (1 occurrences)
Last logged: 22 January 2024 at 8:57:26 pm
Error while setting up renac platform for sensor
Traceback (most recent call last): File “C:\Users\Paul\Desktop\Home Assistant stuff\HassWP_2023.12.4\python-3.11.6.amd64\Lib\site-packages\homeassistant\helpers\entity_platform.py”, line 361, in _async_setup_platform await asyncio.shield(task) File “C:\Users\Paul\Desktop\Home Assistant stuff\HassWP_2023.12.4\python-3.11.6.amd64\Lib\concurrent\futures\thread.py”, line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “C:\Users\Paul\Desktop\Home Assistant stuff\HassWP_2023.12.4\config\custom_components\renac\sensor.py”, line 57, in setup_platform emailSn = login(conf.get(CONF_USERNAME), conf.get(CONF_PASSWORD)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “C:\Users\Paul\Desktop\Home Assistant stuff\HassWP_2023.12.4\config\custom_components\renac\sensor.py”, line 85, in login _LOGGER.info(“Got email id :” + str(r.json()[‘email’])) ~~~~~~~~^^^^^^^^^ KeyError: ‘email’
Any help would be greatly appreciated especially as I can’t see any way to contact the repository owner on github.
