Newbie Setup Question Zigbee / HomeAssistant / Virtual Box / MacOS
Hi, Day2 of Home Assistant and my USB/Zigbee adaptor has arrived from the Amazon fairy.
Plugged into Mac, added that to Virtual Box USB settings for the VM.
When I run do integration, I can select the Conbee 2 option and then it asks for serial path?
So I installed dconz added and it lets me run the Phoscon web app, but chokes on the deconz application.
I loaded SSH and I can get to the cli and use lsusb, which returns
Bus 001 device 001: Id 1d6b:0001
Bus 001 device 002: Id 80ee:0001
And /dev/u* shows jsut usbmon0 and usbmon1
So I tried /dev/usbmon0 (and 1) in the ZHA and that still fails.
Any suggests (apart from getting a Raspberry PI :slight_smile: )
Alyn
I could never get the USB passthrough to work in Virtual Box on MacOS or Windows. I suggest using VMWare, which works perfectly. You can use the free player, but you may have to manually set your config file to use UEFI to get it to boot.
