Newbie: Simple way for updating?
Hi there,
first of all, i’m a newbie to raspberry. I just downloaded an image and installed it via etcher as written here:
https://www.home-assistant.io/getting-started/
Everything ran flawlessly and i started right away with configurung my home :slight_smile:
Now i get a sensor on top of my home tab, telling me there is an update available (0.86.1).
I am running 0.85.1 according to the info page.
Now for my question: when i clock on the sensor, all i see is the meassage itself (Update availabe) and a link to here: https://www.home-assistant.io/docs/installation/updating/
But where do i put the mentioned $ pip3 install --upgrade homeassistant?
I thought there would be an Update-Button somewhere, but i do have to do this manually, right?
I cannot connect via putty (connection refused).
Can someone guide me in the right direction here?
Thnak you very much in advance,
cpo
You need to go into your hass.io menu (on the left), it should inform you of the available update right on the first page and you can update from there
Thanks: @donnae, but i do not see this menu on the left?
I think, i saw that sometimes in the beginning, but it went away somehow? i cannot recall configuring it away :face_with_raised_eyebrow:
Did you turn off discovery?
Did you install Home Assistant or hass.io?
You need either:
discovery:
Or:
hassio:
In configuration.yaml to see the hass.io in the side panel.
If you didn’t install hass.io then no hass.io in side panel.
Oh, so you are not on Hass.io but on Home Assistant. (or what David said, maybe the missing config-entry). Thats a difference and you are in the wrong forum here.
In that case you need to SSH into your pi and run the command there id say
I am a bit confused right now.
first: @DavidFW1960: i commented discovery: out. Once i reactivated it, the hass.io-Panel reappeared on the left side. Then i could update from there - all went well, running 0.86.1 now. Yeah! :slight_smile:
Now for the confusing part (at least for me):
I was under the impression, that i installed a thing called “home assistant” on my pi via https://www.home-assistant.io/getting-started/
Hass.io” was merely a abbreviation for that, wasn’t it?
Could you be so kind and try to explain the difference to me? Are these two different products?
Hass.io is just a different way of installing Home Assistant. There’s a LOT of ways to install it but Home Assistant=Home Assistant however you install it. As per my post leave either discovery: or hassio: in config.
Why did you comment out discovery?
Thank you very much for this explanation! That sheds a light on some things :slight_smile:
I thought, there was ONE prefered way of installation, as there seems only this way to be promoted via the website.
I did comment discovery out because after every restart i did receive a notification about lots of UPNP-Devices that were newly discovered. I just don’t need these at the moment (mostly sensors of my Fritz!-Router) and wanted just to get rid of this notification and unconfigured discoveries.
I did not notice that the hass.io Panel went away with that.
If you want (as David said) you can comment out discovery: and put hassio: in there to still get the HassIO panel to show up
Just did that and now i am satisfied.
Thank you all so much for your quick response and help! :hugs:
You can do this:
discovery:
  ignore:
    - igd
But why? Just add the UPnP/IGD integration and done… it’s not an issue!
Oh, ok.
I did add the integration and all the sensors showed up at the top.
But since they are not of interest to me, i simply was too lazy to hide each and everyone.
Since all the important sensors where added during the first run and i do not plan to add new ones so fast, i figured, i activate it again, when something new is to discover :slight_smile:
I’m playing around with HA for merely 2 days now. Hopefully i will get better at understanding everything :slight_smile:
You will only get sensors you specifically add displaying with lovelace… it was only the old state view where it just showed everything.
I also edited the discovery stuff above as I made a mistake with the exclusion.
Thank you, @DavidFW1960 :slight_smile:
