Hi there,
I tried out some tutorials but every time I get an error of my configuration.
What I need: converting the value of a entity from switch to cover or open close
I have an tasmota device in my garage with 1 relay to control open/close/stop on a Hörmann motor.
A second pin is connected to an reedswitch which is configured in tasmota as switch (switch type dosn’ matter, right?)
So if the door is closed, the switch 2 is on, and if open I get off. I want to see Open and close and have this in one card at the UI , and if I tap on it the switch 1 Relais schould be closed. There is a pulse time set on tasmota, so relais1 releases after 8seconds, that’s the time that the door need to open or close.
So what I understand is first to make a template with a custom sensor. Right? Every template I tried, did bring me an error in my config. I think having some trouble with the spaces.
At my configuration.yaml I have an include to an template.yaml
Code of the configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
# Amazon Echo example configuration.yaml entry
emulated_hue:
listen_port: 80
# Amazon Echo/Alexa stopped working on different ports. Search for "Philips Hue Bridge V1 (round)" in the Alexa App to discover devices.
homeassistant:
customize: !include customize.yaml
sensor: !include sensor.yaml
template: !include template.yaml
My templates.yaml is empty now, after getting errors
