Hi, I’ve installed the Hive integration successfuly via the HACS 3rd party integration and can read all my devices fine. I want to be able to add a button to a dashboard to boost the heating (and another to do the hot water but one thing at a time).
I’m failing to setup a script correctly and am not sure what I am doing wrong so was hoping someone can guide me.
There are the pertinent values I think.
Entity ID for Hive Thermostat: climate.thermostat_3
Service Name: hive.boost_heating
Heating Boost Sensor ID: sensor.thermostat_3_boost
I’ve tried adding a script via the UI and by adding to scripts.yml.
Via scripts.yml
boost_heating:
sequence:
- service: hive.boost_heating
entity_id: "climate.thermostat_3"
time_period: "01:00:00"
temperature: "21.0"
And get the same results either way. When I execute the script an error pops up at the bottom of the screen briefly:
Logger: homeassistant.components.script.boost_heating
Source: helpers/script.py:1147
Integration: Scripts (documentation, issues)
First occurred: 16:57:51 (1 occurrences)
Last logged: 16:57:51
boost_heating: Error executing script. Invalid data for call_service at pos 1: value should be a string for dictionary value @ data['entity_id']
I’m sure I’m close, can anyone let me know what I’m doing wrong?
Steve Davis
