Good morning! I’m sort of with a goal to have different areas (kitchen, family room, hallway, stairs, etc.) turn on when various conditions are met. I’ve done some searching and haven’t found anything on point, but maybe someone out there has seen something similar for a newbie to tinker with… Staring at the automation screen drinking coffee has been unproductive.
Say it’s 11pm to sunrise, motion means lights in an area come on at 25%
Say it’s sunrise to sunset, motion means lights come on to 40% if cloud cover is 35% or less, but brighter like 60% if cloudcover is higher
Say sunset to 11pm, motion means lights come on to 70%
Then, the time to remain on once motion has not been detected would be like 10 mins
Any input to help point me in a solid direction is totally appreciated.
- alias: Entrance motion light on before sunrise
platform: state
entity_id:
- binary_sensor.motion_sensor_xxx
to: 'on'
condition:
- condition: sun
before: sunrise
- service: light.turn_on
entity_id: light.entrance
brightness: 255
- alias: Entrance motion light on after sunset
platform: state
entity_id:
to: 'on'
condition:
- condition: sun
after: sunset
brightness: 255
- alias: Entrance no motion light off
platform: state
entity_id:
to: 'off'
for:
minutes: 10
- service: light.turn_off
entity_id: light.entrance_light
before sunrise = midnight to runrise
after sunset = sunset to midnight
adjust bright to level you want max =255
Weather forecast for cloud cover wont be accurate, i would use luminance sensor in the motion sensor for that purpose. Look in the developer tools state to see you got any luminance sensor in those?
Here is my luminance automation, I use OR condition because i want the light to turn on regardless if it day time or night, as long as it dark. And when it night time it will turn on regardless if it bright or not to unaffected by nearby light and itself. Probably you can customize it for your weather condition, use AND if you want all condition met.
platform: state
entity_id:
to: 'on'
condition:
condition: or
conditions:
- condition: state
entity_id: sun.sun
state: "below_horizon"
- condition: numeric_state
entity_id: sensor.xxx_illuminance
below: 800
Thank you @huu and @MickW69 for the input thus far.
Sadly, I have Lutron Caseta as the house’s smart light and sensor setup. Lutron’s sensor doesn’t include luminance. I was able to get the deCONZ Zigbee controller working and added some Aqara sensors using it for the water leaks and humidity readings. I’m trying to find a similar sensor to toss on that for light levels.
The aqara motion sensor you mention is small enough to be wife friendly (the diameter of the round part is about CR 2032 battery) but it also need a aqara hub so it an added cost. Since you are already in the Lutron ecosystem there is a “Lutron Daylight Sensor” you can use. Not sure about the size or if it will fit in to your existing setup or compatibility with HA.
note; The new aqara light sensor is not compatible with existing gateway. Need a newer “Smart Hub”
Yeah, so the Lutron sensor is part of a different ecosystem that isn’t connected smart home oriented. If aqara isn’t compatible with my setup, I may buy one of the Xaiomi’s to try out. It may just be that I go motion sensor only. I was trying to cut out electricity usage, albeit LEDs are low footprint, in rooms with lots of windows if it’s sunny out basically.
I ordered Hue sensors. Expensive but seems like the best option and won’t need the Hue hub from what I’ve read. Like everything else useful they are backordered so working on a solution with cloudcover for now.
How’s this look? (I think I got spacing correct but Google Docs is a real pain in the rear trying to correct me)
- id: '1899958999001'
alias: 'Kitchen lights on with some cloud cover’
platform: state
entity_id:
- binary_sensor.kitchen_occupancy
to: on
condition:
condition: and
conditions:
entity_id: sensor.openweathermap_cloud_coverage
domain: sensor
above: 20
below: 50
- condition: sun
before: sunset
before_offset: '-01:00:00'
- condition: time
after: '09:00'
entity_id: light.kitchen_main_lights
brightness: 100 # 255 is max
entity_id: light.kitchen_under_cabinet
mode: single
- id: '1899958999002'
alias: 'Kitchen lights off’
platform: state
entity_id:
to: 'off'
for:
minutes: 10
I guess technically the on should be occupied since it’s an occupancy sensor. Other than that, how bad off am I?
Read otherwise. ( occupancy: on means occupied, off means not occupied (clear)) So the above remains out to see how bad y’all think it is. Thanks a lot!
I tried running it though YAML Checker and it came out with an error. But, the error is something that is written the same way and copied from an automation with the GUI. Adding it via File Editor is coming up with the same error as well.
bad indentation of a mapping entry at line 172, column 23:
before_offset: ‘-01:00:00’
@huu thank you! It didn’t kick back an error so let’s see how it works out today.
In re domain and mode, I just saw those in my original automations and thought they were necessary. I assume they are meaningless by your question? lol
Working on the rest of my kitchen schema to cover 24 hours. I’m not sure how the late night and morning one’s look. I say this because the after/before times are on different days?
- id: '1899958999005'
alias: 'Kitchen lights evening time'
platform: state
entity_id:
to: on
condition:
condition: and
conditions:
- condition: sun
after: sunset
after_offset: '-01:00:00'
- condition: time
before: '22:30'
brightness: 85
brightness: 80
mode: single
- id: '1899958999006'
alias: 'Kitchen lights late night'
platform: state
entity_id:
to: on
condition:
- condition: time
after: '10:30'
before: '06:00'
brightness: 85
brightness: 80
mode: single
- id: '1899958999007'
alias: 'Kitchen lights morning'
platform: state
entity_id:
to: on
condition:
- condition: time
after: '06:00'
before: '09:00'
brightness: 85
brightness: 80
mode: single
Yes it can span across day, but you late night suppose to be after 22:30:00 (not 10:30?) before 06:00:00 = 10:30pm to 6am next day.
And your everning time… after sunset (=6pm to midnight) and before 22:30;00 (=10:30pm to midnite) since it an AND condition it would only true between 10:30pm to midnight (eg if sunset at 6pm)
After 6am before 9am will be only between 3 hours 6 - 9 am on that same fay
Scroll down to “ time conditions “ section here for a good explanation of before and after conditions
Great catch on my error on the 1030/2030! Thank you. Fixed that.
I reviewed the link you provided and, to my novice eyes, the condition for 1 hour before sunset until 2230 seems to look correct. Am I missing something? The objective is to use the brightness level set for motion for the evening hours starting an hour before sunset because it’s quite dark at that point inside the house.
condition:
condition: and
conditions:
- condition: sun
after: sunset
- condition: time
before: '22:30'
Hmm reading that again i think the before 22:30:00 means from midnight to 22:30 ie it span the whole day time… this section
Note that if only before key is used, the condition will be truefrom midnight until the specified time.
If only after key is used, the condition will be true from the specified time until midnight
I was looking at it like this: an AND condition is used, so if the time constraint is out of bounds with sunset then it won’t turn on and is rendered false to continue to the action.
Well this is fun. I added all that jazz in and now I get this message:
2021-08-16 10:49:20 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [mode] is an invalid option for [automation]. Check: automation->action->1->mode. (See /config/configuration.yaml, line 9).
Line 9 is: group: !include groups.yaml
groups.yaml is blank.
My entire automation yaml is:
- id: '1628687582995'
alias: Close Velux shades if too hot 89F
description: ''
- type: temperature
platform: device
device_id: 45a6ae64e81ca2ca86450430756e47f8
entity_id: sensor.openweathermap_temperature
domain: sensor
above: 88
below: 200
for:
hours: 0
minutes: 10
seconds: 0
milliseconds: 0
condition:
- condition: time
after: '10:00'
before: '16:45'
- condition: sun
before: sunset
before_offset: -02:00:00
- device_id: 6e376a903f839357f22bd95fddfec877
domain: cover
entity_id: cover.velux_left
type: set_position
position: 50
- device_id: 60693a2a7d78a5b42abd34fa7988ff1f
domain: cover
entity_id: cover.velux_right_2
type: set_position
position: 52
mode: single
- id: '1628687689731'
alias: Keep Velux Shades open if 25-86F
description: ''
- type: temperature
platform: device
device_id: 52a7c56c24bf78a8eba58757bac2625e
entity_id: sensor.temperature_14
domain: sensor
above: 25
below: 86
condition:
- condition: sun
before: sunset
before_offset: -00:15:00
- condition: time
after: '11:00'
before: '19:00'
domain: cover
type: set_position
position: 100
domain: cover
type: set_position
position: 100
mode: single
- id: '1628687741304'
alias: Morning open velux shades
description: ''
- platform: sun
event: sunrise
offset: -00:10:00
condition: []
domain: cover
type: set_position
position: 100
domain: cover
type: set_position
position: 100
mode: single
- id: '1628687781331'
alias: Nightly Close velux shades
description: ''
- platform: sun
event: sunset
offset: +01:00:00
condition: []
domain: cover
type: set_position
domain: cover
type: set_position
mode: single
- id: '1692801842292'
alias: Master Bath Hygrostat On
platform: state
entity_id: binary_sensor.bathroom_hygrostat
to: 'on'
- service: switch.turn_on
entity_id: switch.mast_bath_dehumidifier
- id: '1692801842293'
alias: Master Bath Hygrostat Off
platform: state
to: 'off'
- service: switch.turn_off
- id: '1628851499528'
alias: 'Close Garage Door if Phones Are NOT Home'
description: ''
- platform: device
device_id: 3388b53564883d13ea40679464a714a5
domain: cover
entity_id: cover.garage_door
type: opened
for:
hours: 0
minutes: 30
seconds: 0
milliseconds: 0
condition:
- condition: and
conditions:
- condition: device
device_id: b3537ca6e6de81866dad95f9a3e4bf2c
domain: device_tracker
entity_id: device_tracker.pixel_5
type: is_not_home
- condition: device
device_id: f05b8bb0f7b5f1d39e70ddc602b08f7a
entity_id: device_tracker.pixel_5_gaby
type: is_not_home
- device_id: 3388b53564883d13ea40679464a714a5
domain: cover
type: close
mode: single
alias: 'Kitchen lights on with some cloud cover'
platform: state
entity_id:
to: on
condition:
condition: and
conditions:
domain: sensor
above: 20
below: 49
- condition: sun
before: sunset
- condition: time
after: '09:00'
brightness: 35
brightness: 60
mode: single
alias: 'Kitchen lights off'
platform: state
entity_id:
to: 'off'
for:
minutes: 5
- id: '1899958999003'
alias: 'Kitchen lights on with lots of cloud cover'
platform: state
entity_id:
to: on
condition:
condition: and
conditions:
domain: sensor
above: 49
- condition: sun
before: sunset
- condition: time
after: '09:00'
brightness: 45
brightness: 70
mode: single
- id: '1899958999004'
alias: 'Kitchen lights on with no cloud cover'
platform: state
entity_id:
to: on
condition:
condition: and
conditions:
domain: sensor
below: 20
- condition: sun
before: sunset
- condition: time
after: '09:00'
brightness: 30
brightness: 30
mode: single
platform: state
entity_id:
to: on
condition:
condition: and
conditions:
- condition: sun
after: sunset
- condition: time
before: '22:30'
brightness: 80
brightness: 85
mode: single
platform: state
entity_id:
to: on
condition:
- condition: time
after: '20:30'
before: '06:00'
brightness: 20
brightness: 50
mode: single
platform: state
entity_id:
to: on
condition:
- condition: time
after: '06:00'
before: '09:00'
brightness: 60
brightness: 80
mode: single
