I should start by saying that I am very new to both home assistant and ESPHome. I’ve been learning SoC programming for a few months now and have successfully made sensors with arduino & ESP32 boards. However, I’m trying to use ESPHome to integrate these into my overall monitoring.
Through ESPHome, I’m able to initial the board with no issue. In Home Assistant, I can incorporate it into my overall system. BUT! When I try and update the board wirelessly (or any other method, for that matter) it fails, and I can’t figure out why. I’ve tried different versions, different frameworks, etc. but no matter what I do, I get the same error.
I’m running Home Assistant off of an old Raspberry Pi 3 (I have a 4 I’m going to move it to, once I find a new home for my media server), and developing on an ARM Mac. I know the processor architecture has been an issue for me before, so I wasn’t sure if that was the problem with my current situation.
Any help would be greatly appreciated!
/data/cache/platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld: cannot find -lnosys
collect2: error: ld returned 1 exit status
*** [/data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/firmware.elf] Error 1
Here is my config file:
esphome:
esp32:
board: nodemcu-32s
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "some encryption key"
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-47C45C"
password: "a password"
And this is the log with the error at the very bottom.
INFO Reading configuration /config/esphome/esphome-web-47c45c.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esphome-web-47c45c (board: nodemcu-32s; framework: arduino; platform: platformio/espressif32 @ 5.2.0)
Removing unused dependencies...
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Update @ 2.0.0
|-- noise-c @ 0.1.4
| |-- libsodium @ 1.10018.1
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/api/api_connection.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/api/api_server.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/api/list_entities.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/api/proto.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/api/subscribe_state.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/api/user_services.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/esp32/core.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/esp32/gpio.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/esp32/preferences.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/logger/logger.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/md5/md5.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/mdns/mdns_component.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/network/util.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/ota/ota_component.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/socket/socket.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/wifi/wifi_component.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/core/application.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/core/color.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/core/component.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/core/component_iterator.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/core/controller.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/core/entity_base.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/core/helpers.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/core/log.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/core/scheduler.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/esphome/core/util.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/src/main.cpp.o
Building /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/bootloader.bin
Creating esp32 image...
Successfully created esp32 image.
Generating partitions /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/partitions.bin
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib64d/WiFi/WiFi.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib64d/WiFi/WiFiAP.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib64d/WiFi/WiFiClient.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib64d/WiFi/WiFiGeneric.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib64d/WiFi/WiFiMulti.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib64d/WiFi/WiFiSTA.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib64d/WiFi/WiFiScan.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib64d/WiFi/WiFiServer.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib64d/WiFi/WiFiUdp.cpp.o
Archiving /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib64d/libWiFi.a
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib915/ESPmDNS/ESPmDNS.cpp.o
Archiving /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib915/libESPmDNS.a
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libbc6/Update/HttpsOTAUpdate.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libbc6/Update/Updater.cpp.o
Archiving /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libbc6/libUpdate.a
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_core/ed25519/core_ed25519.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_core/ed25519/core_ristretto255.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_core/ed25519/ref10/ed25519_ref10.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_hash/crypto_hash.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_scalarmult/crypto_scalarmult.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_stream/chacha20/stream_chacha20.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_stream/crypto_stream.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/crypto_verify/sodium/verify.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/sodium/codecs.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/sodium/core.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/sodium/runtime.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium/sodium/utils.c.o
Archiving /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libdca/libsodium.a
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/openssl/cipher-aesgcm.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/ref/cipher-aesgcm.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/ref/cipher-chachapoly.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/ref/dh-curve25519.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/ref/hash-blake2b.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/ref/hash-blake2s.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/ref/hash-sha256.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/sodium/cipher-aesgcm.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/sodium/cipher-chachapoly.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/sodium/dh-curve25519.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/sodium/hash-blake2b.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/backend/sodium/hash-sha256.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/crypto/aes/rijndael-alg-fst.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/crypto/blake2/blake2b.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/crypto/blake2/blake2s.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/crypto/chacha/chacha.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/crypto/donna/curve25519-donna-c64.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/crypto/donna/curve25519-donna.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/crypto/donna/poly1305-donna.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/crypto/sha2/sha256.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/crypto/sha2/sha512.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/crypto/x25519/x25519.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/cipherstate.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/dhstate.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/errors.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/handshakestate.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/hashstate.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/internal.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/names.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/patterns.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/rand_os.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/rand_sodium.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/randstate.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/signstate.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/symmetricstate.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/noise-c/protocol/util.c.o
Archiving /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/lib17f/libnoise-c.a
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/Esp.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/FirmwareMSC.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/HWCDC.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/HardwareSerial.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/IPAddress.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/IPv6Address.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/MD5Builder.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/Print.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/Stream.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/StreamString.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/Tone.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/USB.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/USBCDC.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/USBMSC.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/WMath.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/WString.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/base64.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/cbuf.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-adc.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-bt.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-cpu.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-dac.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-gpio.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-i2c-slave.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-i2c.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-ledc.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-matrix.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-misc.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-psram.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-rgb-led.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-rmt.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-spi.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-time.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-timer.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-tinyusb.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-touch.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/esp32-hal-uart.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/firmware_msc_fat.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/libb64/cdecode.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/libb64/cencode.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/main.cpp.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/stdlib_noniso.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/wiring_pulse.c.o
Compiling /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/FrameworkArduino/wiring_shift.c.o
Archiving /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/libFrameworkArduino.a
Linking /data/esphome-web-47c45c/.pioenvs/esphome-web-47c45c/firmware.elf
========================= [FAILED] Took 488.43 seconds =========================
