Newbie, yaml color states not working
I have no experience with yaml.
My background is old school, programing in assembly and C
I want to create an automation, that change the rgb color
I followed a tutorial that create a rgb_esther in the config.yaml
input_select:
rgb_esther:
name: RGB Colors Esther
options:
- red
- green
- blue
I know that input works as I used another automation to cycle it
service: input_select.select_next
entity_id: input_select.rgb_esther
cycle: true
I am having troubles with
color_name: ‘{{ states(’‘input_select.rgb_esther’’) }}’
It is not doing what it supposed to do
I do not know how to troubleshoot the {{…}} Section and see it it return the expected red, green or blue string
Please post the full script/automation/card configuration you are using…
we need to know the context of color_name: '{{ states("input_select.rgb_esther") }}'.
Also, please use the Preformatted text tool to format your code blocks
How to Help Us Help You: Guideline #11
