Newby advice on set up for Ikea TRÅDFRI GU10 lamps
My first post so please be gentle.
Am just starting out with HA. Got it installed and running, just bought a Skyconnect device.
Am researching what GU10 lamps to buy for our new Kitchen. Will need about 16 of them.
It seems like these:
are a very good price for a white dimmable and tunable lamp.
My question is do I need to buy the Ikea remote control or the DIRIGERA hub to get them to work/register them etc…? Or can I just use “native” ZHA over the SkyConnect device?
Thanks in advance
Al
As far as I know they are zigbee so should just work with you skconnect.
As always read the docs :slight_smile:
Buying these bulbs will be an expensive way of automating your lights, when you could just use some kind of behind the switch relay or smart switch. And you will have to disable your light switch, or else you will find your smart bulbs switched off, and if you disable your switch, no one without an app will be able to turn on your lights. It all sounds nice being able to dim or change the warmness of your bulbs but the reality is that will probably never happen once you have the setting you like.
I just wanted to update this thread for other others. I now have about 30 of these lamps, two Ikea Zigbee repeaters, and three of their new Vallhorn PIR sensors. All work really well with Home Connect - directly. You don’t need the Ikea bridge/ I just have the Home Assistant skyconnect dongle.
Their white lamps are excellent value IMHO (I’ve not seen any smart lamps cheaper than this). You can control the colour temperature and brightness and they are 345 lumens so bright enough for a kitchen.
Hi
Thanks for the update, but how did you connect them? I have the sky connect too, but don’t seem to be able to get it to connect
UPDATED ugh so you have to get the lamps that close to pair them. Well that’s boring!
Hat
How close is “close” when it comes to the USB stick & the GU10 lamp ? an inch ???
Haven’t had any success pairing it directly, i mean between the TRÅDFRI bulb ↔ the Zigbee USB stick.
The GU10 ones have never been paired before with anything else… I am opening the new box & directly trying to make it work with home assistant’s zigbee usb stick.
Other TRÅDFRI E26 bulbs that are lying around, pair directly to the USB stick, without any problems!.. Not sure what is with the GU10…
The GU10 model that I am experimenting is this one:
LED bulb GU10 380 lumen, smart/wireless dimmable white spectrum
After a few hours of moving back and forth my house with the rpi, I found that the recent Tradfri GU10 LED2106R3 bulbs can be reset for pairing by toggling the switch 6 times. Then they start to flicker showing they are on pairing mode.
https://manuals.plus/ikea/tradfri-led-bulb-gu10-380-lumen-wireless-dimmable-manual
