Newby needs help for installation
Hello
I kindly request your help to solve my installation issue.
I use a raspi 3B
I strictly followed the steps of the page https://www.home-assistant.io/getting-started/ - with the 32 bits version
For the USB stick, iI used the default example of the page https://github.com/home-assistant/hassos/blob/dev/Documentation/network.md
I should say, I didn’t understand the means of id and uuid - so I took as it
When I start the raspi, all messages are ok (ie no error displayed)
But after a while, it loops every avg 315s with :
IPv6 : ADDRCONF(NETDEV_UP): wlan0: link is not ready
brcmfmac: power management disabled
What is strange for me, is my home network is ony IPv4 (not v6)
And during the bootup, I saw some “link is ready”
If I hit return, and login root, I have the a prompt
And all commands are answered but “network” or “ne”, where I have the message :
No valid action detected
After a “ho shutdown”, I can stop the system :frowning: and write this message
Thks for your help
Lionel
've installed
Have you tried navigating to http://ip-address-of-hassio:8123?
It sounds like it’s working to me but you don’t access via the server… you use another web browser.
Hello David
Unfortunately, it doesn’t work, whatever the browser used.
Even the ping doesn’t work
If you cannot ping the device by IP, then you have a problem at a lower level than Home Assistant.
