I’m new to Home Automation in General.
I’m New to Home Assistant in the way that I tried to install it in Virtualbox to get an idea of this Software, And I failed so far.
However my failure got me thinking.
I noticed that there are different ways to install Home Assistant and I would like to know really what the difference is ?. More specifically what is the best way to install when you have a Windows 10 standing as a Server already.
As well as introduce my self to you all.
I’m a Software Developer so I’m used to having to tinker with my things to make it work the way I want it which is specifically why my current choice is to try Home assistant out.
Also the problem I ran in to is best shown with where I am stuck ATM.
Basically I have no idea what to do from here on forward.
I’ve got a little Ubuntu, Red Hat and Linux from Scratch experience.
but must confess my primary system have always been Windows.
I wasn’t sure which category to put this one in so if I’m in the wrong one please point me in the right direction.
What have you tried? I successfully ran in VirtualBox when I first evaluated HA. I had the NIC in bridged mode to get a network address. I tend to like Debian because the server itself does not need the overhead of a graphical environment.
Home Assistant itself is a Python application. It can either be installed in a Python venv or there is a Docker installation.
Hassbian is a Raspian based venv image of Home Assistant. The Hassbian scripts help with common tasks.
but What I also hear you say is I should switch out my windows 10 for a linux server instead as I would be able to run this directly through docker on a linux server.
makes me thinking is it also possible to run directly from docker on a windows 10 machine ?
Install Ubuntu or Debian in a VirtualBox VM & then install Hassio. I ran it that way for a while until I purchased a Raspberry Pi 3B+ for Home Assistant. I ran Hassio on Raspbian Lite for a while but an currently running an older (0.90.2) version of Home Assistant in a venv.
Installation on Windows is not officially supported and you could have other issues.
Development is very quick, with full releases every 2-3 weeks, usually with bugs & breaking changes. There are 2 full-time developers, 1 on Home Assistant & 1 on Hassio. I moved back from 0.92.2 to 0.90.2 to get a stable build that works for me until things settle down a bit.
