arretx
(Jon Griffith)
1
My new HASS.io setup under Docker was installed without the homeassistant:
configuration, as the default_config:
seems to be the way now.
Question:
Can I still implement custom settings under homeassistant:
without screwing things up?
Which one takes precedence?
Yes.
Neither ‘takes precedence’, if you configure something within homeassistant (like packages for example) then that’s where you configured it.
arretx
(Jon Griffith)
3
Got it. I was going to test out white-listing external folders to access files on my Ubuntu box but didn’t want to muck anything up. Thanks.
