Newer template sensor config type with split config
I’m attempting to adhere to standards and leverage the newer standard for template sensors.
I leverage a split config where I have a sensors.yaml file.
Typically I would add a template sensor like this which works.
    sensors:
      speedtest_download_rounded:
        friendly_name: Speed Test Download Rounded
        unique_id: sensor.speedtest_download_rounded
        value_template: '{{ states("sensor.speedtest_download") | round(0) }}'
Attempting to leverage the new standard I have this:
- template:
      - sensor:
          - name: "Runtime Remaining"
            state: "{{ states('input_text.sprinkler_qr_timer_zone1') }}"
But this format fails with error:
Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None.
I’m sure this is simple but I have yet to figure it out with the new formatting.
The top level for the new format is template, but by putting it in your sensors.yaml you are using setting sensor as the top level. You need to either create a new file template.yaml with an include in your main configuration file, or place your new sensors in your packages folder if you prefer to do it that way.
I was thinking of creating a template.yaml. Thanks for clarifying I was headed in the right direction.
