I’m still new to HA but getting better with it. Few weeks back when I started over to setup my HA, I added 4 Tasmota SmartPlugs from 2 different Vendors (Refoss and Nous) which I also recently bought. They came with a quite recent Tasmota Version, so i did not have much trouble to get them added to HA.
Yesterday I found an old Sonoff Gosund SP1 smart plug that I must have bought like 4 or 5 years ago and it had Tasmota 6.4.1.
So I remembered that Autodiscovery was only possible with newer versions and I went an hour through the migration path and now have the latest Tasmota (14.2.0) on this old smart plug.
To my surprise, when i switched to the browser window with HA open, it was already discovered!
However, It does not show any values nor does it let me control the switch (on/off).
I tried to search but i could not find any other post that discusses the situation where some plugs work without any problems, but another one does not.
The IP of the plug is correct, when I click the “visit” link, it will open the smart plugs web ui (from which i can control the switch).
I rebooted my HA, but it did not change anything.
The Version information says the following:
Gosund SP1 v23
GosundSP1_Tasmota2b
Program Version 14.2.0 (release-tasmota)
Build Date & Time 2024-08-14T12:36:35
Core/SDK Version 2_7_7/2.2.2-dev(38a443e)
Uptime 0T02:52:40
Flash Write Count 18338 at 0xF5000
Boot Count 50
Restart Reason Power On
Friendly Name 1 GosundSP1_Tasmota2b
AP2 Information SSId XXXXXXXXX
RSSI 64%, -68 dBm
Mode 11n
Channel 5
BSSId 74:83:C2:3A:74:83
Hostname GosundSP1-Tasmota2b-0808
MAC Address 60:01:94:C2:E3:28
IP Address (WiFi) 192.168.2.95
Gateway 192.168.2.1
Subnet Mask 255.255.255.0
DNS Server1 192.168.2.30
DNS Server2 0.0.0.0
HTTP API Enabled
MQTT Host 192.168.2.11
MQTT Port 1883
MQTT User DVES_USER
MQTT Client DVES_C2E328
MQTT Topic GosundSP1_Tasmota2b
MQTT Group Topic 1 cmnd/sonoffs/
MQTT Full Topic cmnd/GosundSP1_Tasmota2b/
MQTT Fallback Topic cmnd/DVES_C2E328_fb/
MQTT No Retain Disabled
Emulation None
ESP Chip Id 12772136 (ESP8285N08)
Flash Chip Id 0x144051 (DOUT)
Flash Size 1024 KB
Program Flash Size 1024 KB
Program Size 648 KB
Free Program Space 352 KB
Free Memory 24.1 KB
I compared the config/info with one of the working plugs and noticed, the GroupTopic is the same for the others, but it is different from the not working one
MQTT Port 1883
MQTT User DVES_USER
MQTT Client DVES_1CD4AB
MQTT Topic tasmota_%06X
MQTT Group Topic 1 cmnd/tasmotas/
MQTT Full Topic cmnd/tasmota_1CD4AB/
MQTT Fallback Topic cmnd/DVES_1CD4AB_fb/
But apparently I can’t figure out how to change the Group Topic via webui/console.
Anyone has ever had this issue and has some clues?
