I have been having trouble getting the news rss feed on my dashboard. The documentation is not to clear on the widget type configuration and I was hoping someone could help point out what I am doing wrong here.
thanks for the response. Sorry for not including that info in the first post, Ive been using HA for about 3 months now and just started messing with dashboard the past couple days. I get no mention of the entity on the dashboard ssh session but not sure where I can find a better log? It just shows the dashboard connect but without any errors, on the dashboard it self I get entity not found.
2017-08-20 09:42:45.147058 INFO New dashboard connected: HADashboard
2017-08-20 09:45:10.119819 INFO Dashboard disconnected
Woud you happen to know if it is possible to change the color of text and buttons? And make certain text bold? I can change the background easily with widget style but was trying to change the color of some of the text and make it a little heavier…easier to read. Some buttons light up a color i would prefer not to use as well. Maybe asking a lot here since I haven’t found much…
I am noticing I can learn a lot just clicking through these files…but is there somewhere that lists valid options to change text styles and colors?
I also have been having issues with a switch or a boolean not changing states within ha. So if I turn it on by a iPad dashboard then the state does not change within HA to activate the automation. I have been reading about an HAPush that sounds like it keeps the current state correct on both HA and dashboard regardless of where the state was changed which is great cause i also use emulated hue. It may be needed to change the state within ha regardless? Most the posts around hapush are back 6+ months ago…which doesn’t seem like long but the way this is being developed I’m curious if it is still needed?
If there is somewhere you might be able to point me with a little documentation on either item or some key terms to google i would appreciate that as well. I don’t know if I am using the wrong words but I do not get much in return when searching google or communities. Im ready to hang a few up here shortly I love the progress. I just about have everything working 100% very pleased thank you thank you.
