Have anyone got this combination to work? Sending a dim command from its remote makes HA pick it up as a “light”. Sending an on/off command makes HA pick it up as a switch. Neither works for controlling the dimmer. Or it works once and then stops. My Telldus Znet Lite v2 controls it just fine so there seems to be something secret about the messages that needs sending. All other Nexa switches work beatifully with the RFXCOM RFXtrx integration.
Hi Björn, sorry for coming back to an old topic. I have an rfxcom to read some 433 temperature sensors, that works fine. But I also want to control a couple of Nexa switches, but Nexa does not come up in the list. It seems you managed that from the above. How did you do that? someone suggested AC, but that is not in the list either.
