Nexa selflearning on/off switch not workning (tellstick duo)
After updatning HASS to 0.57.2 my selflearning swites (on/off) won’t trigger automations. The swithes is magnet contacts from Nexa. My tellstick duo sends and recives the signals and it gets information about a new state when a magnet contact is seperate.
I don’t get any errors in loggfile when I separate the magnet contacts. I can see the switch i HASS but I think that HASS don’t see then a state i update.
Any idea to fix the problem?
My HASS i running in a virtiuralenv that have python 3.6.
I have the same issue after upgrading to 0.57.2 with Nexa LWST-605 built in switches.
Automations run when triggering the switch from the state UI in HASS so this is most likely a problem with the Tellstick component.
The same problem i have.
I don’t get any error in loggbook. Do you?
I see some aiohttp exceptions. Looked at the tellstick.py switch in the master branch of the repo and discovered this issue https://github.com/home-assistant/home-assistant/pull/10384, so it will hopefully be solved in 0.57.3.
Will try to patch my current installation when I get home and get back on whether this solves the issue.
Patching tellstick.py solved it, but no need to do that any longer since 0.57.3 has fixed this problem. https://home-assistant.io/blog/2017/11/04/release-57/#release-0573---november-11
I’m experiencing the same problem, but I’m already on 0.60 now. Do I need to update anything else?
