Change the id and unit for your device.
Config for shell command, since dimlevel is not working with the pilight switches in home-assistant
shell_command:
nexawmr_252: /usr/local/bin/pilight-send -p {{protocol}} -i {{id}} -u {{unit}} --{{power}} {{dimlevel}}
Config for light
light:
lights:
nexawmr_252:
friendly_name: "LampLamp"
turn_on:
- service: shell_command.nexawmr_252
data_template:
protocol: kaku_dimmer
id: 44444444 #change this
unit: 0 #change this
power: "on"
dimlevel: "-d 15"
turn_off:
data_template:
power: "off"
dimlevel: ""
set_level:
data_template:
power: "on"
dimlevel: "-d {{ (brightness | float / (255/15)) | int }}"
