Excellent!
The lovelace thermostat card appears to be fully functional.
Edit: It isn’t updating properly. The status has shown idle from the start even though the fan and cooling have been going. It seems to take temp changes, though.
But nothing seems to work on the pop-up with all of the attributes.
They show the correct values, but changing settings gives errors. Here are a couple:
SETTING HUMIDITY HERE:
2019-06-01 13:31:59 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1802424304] 'NexiaThermostat' object has no attribute 'get_device_id'
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/websocket_api/commands.py", line 121, in handle_call_service
connection.context(msg))
File "/usr/local/lib/python3.7/site-packages/homeassistant/core.py", line 1141, in async_call
self._execute_service(handler, service_call))
File "/usr/local/lib/python3.7/site-packages/homeassistant/core.py", line 1163, in _execute_service
await handler.func(service_call)
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_component.py", line 194, in handle_service
required_features
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 316, in entity_service_call
future.result() # pop exception if have
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 337, in _handle_service_platform_call
await getattr(entity, func)(**data)
File "/config/custom_components/nexia/climate.py", line 91, in set_humidity
self._device.set_target_humidity(humidty / 100.0)
File "/config/custom_components/nexia/nexia_thermostat.py", line 384, in set_target_humidity
url = self._get_thermostat_put_url("humidity_setpoints")
File "/config/custom_components/nexia/nexia_thermostat.py", line 342, in _get_thermostat_put_url
return "/houses/" + str(self.house_id) + "/xxl_thermostats/" + str(self.get_device_id()) + ("/" + text if text else "")
AttributeError: 'NexiaThermostat' object has no attribute 'get_device_id'
SETTING TEMP HERE:
2019-06-01 13:40:49 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1802424304] unsupported operand type(s) for +: 'NoneType' and 'int'
required_features
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 339, in _handle_service_platform_call
await func(entity, data)
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/climate/__init__.py", line 559, in async_service_temperature_set
await entity.async_set_temperature(**kwargs)
File "/config/custom_components/nexia/climate.py", line 152, in set_temperature
if new_heat_temp + deadband > max_temp:
TypeError: unsupported operand type(s) for +: 'NoneType' and 'int'
Thanks for getting this going!!!
