Did you get this figured out? I’m currently having a different issue. I see traffic in HA logs when i ring the bell, but nothing happens to the ‘state’ of the doorbell in HA. Pressing the doorbell results in this:
2018-05-01 13:53:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.doorbell, old_state=<state zwave.doorbell=initializing; node_id=91, node_name=Doorbell, manufacturer_name=Nexia, product_name=DB100Z Doorbell Sensor, query_stage=CacheLoad, is_awake=False, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'beaming'}, sentCnt=1, sentFailed=1, retries=0, receivedCnt=12, receivedDups=7, receivedUnsolicited=12, sentTS=2018-05-01 13:40:17:854 , receivedTS=2018-05-01 13:52:54:686 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=25200, friendly_name=Doorbell @ 2018-05-01T13:39:13.264407-04:00>, new_state=<state zwave.doorbell=initializing; node_id=91, node_name=Doorbell, manufacturer_name=Nexia, product_name=DB100Z Doorbell Sensor, query_stage=CacheLoad, is_awake=False, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'beaming'}, sentCnt=1, sentFailed=1, retries=0, receivedCnt=13, receivedDups=7, receivedUnsolicited=13, sentTS=2018-05-01 13:40:17:854 , receivedTS=2018-05-01 13:53:02:516 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=25200, friendly_name=Doorbell @ 2018-05-01T13:39:13.264407-04:00>>
2018-05-01 13:53:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.doorbell_alarm_type, old_state=<state sensor.doorbell_alarm_type=0; node_id=91, value_index=0, value_instance=1, value_id=72057595570700289, unit_of_measurement=, friendly_name=Doorbell Alarm Type @ 2018-05-01T13:52:54.789991-04:00>, new_state=<state sensor.doorbell_alarm_type=0; node_id=91, value_index=0, value_instance=1, value_id=72057595570700289, unit_of_measurement=, friendly_name=Doorbell Alarm Type @ 2018-05-01T13:53:02.620340-04:00>>
2018-05-01 13:53:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.doorbell_alarm_level, old_state=<state sensor.doorbell_alarm_level=0; node_id=91, value_index=1, value_instance=1, value_id=72057595570700305, unit_of_measurement=, friendly_name=Doorbell Alarm Level @ 2018-05-01T13:52:54.791145-04:00>, new_state=<state sensor.doorbell_alarm_level=0; node_id=91, value_index=1, value_instance=1, value_id=72057595570700305, unit_of_measurement=, friendly_name=Doorbell Alarm Level @ 2018-05-01T13:53:02.621490-04:00>>
2018-05-01 13:53:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.doorbell_sourcenodeid, old_state=<state sensor.doorbell_sourcenodeid=0; node_id=91, value_index=2, value_instance=1, value_id=72057595570700321, unit_of_measurement=, friendly_name=Doorbell SourceNodeId @ 2018-05-01T13:52:54.793869-04:00>, new_state=<state sensor.doorbell_sourcenodeid=0; node_id=91, value_index=2, value_instance=1, value_id=72057595570700321, unit_of_measurement=, friendly_name=Doorbell SourceNodeId @ 2018-05-01T13:53:02.624282-04:00>>
2018-05-01 13:53:02 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.doorbell_power_management, old_state=<state sensor.doorbell_power_management=0; node_id=91, value_index=11, value_instance=1, value_id=72057595570700465, unit_of_measurement=, friendly_name=Doorbell Power Management @ 2018-05-01T13:52:54.795528-04:00>, new_state=<state sensor.doorbell_power_management=1; node_id=91, value_index=11, value_instance=1, value_id=72057595570700465, unit_of_measurement=, friendly_name=Doorbell Power Management @ 2018-05-01T13:53:02.625546-04:00>>
releasing the doorbell button seems to cause the same traffic (other than timestamps/incremental counts):
2018-05-01 13:53:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zwave.doorbell, old_state=<state zwave.doorbell=initializing; node_id=91, node_name=Doorbell, manufacturer_name=Nexia, product_name=DB100Z Doorbell Sensor, query_stage=CacheLoad, is_awake=False, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'beaming'}, sentCnt=1, sentFailed=1, retries=0, receivedCnt=13, receivedDups=7, receivedUnsolicited=13, sentTS=2018-05-01 13:40:17:854 , receivedTS=2018-05-01 13:53:02:516 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=25200, friendly_name=Doorbell @ 2018-05-01T13:39:13.264407-04:00>, new_state=<state zwave.doorbell=initializing; node_id=91, node_name=Doorbell, manufacturer_name=Nexia, product_name=DB100Z Doorbell Sensor, query_stage=CacheLoad, is_awake=False, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={'routing', 'beaming'}, sentCnt=1, sentFailed=1, retries=0, receivedCnt=14, receivedDups=7, receivedUnsolicited=14, sentTS=2018-05-01 13:40:17:854 , receivedTS=2018-05-01 13:53:04:626 , lastRequestRTT=0, averageRequestRTT=0, lastResponseRTT=0, averageResponseRTT=0, battery_level=100, wake_up_interval=25200, friendly_name=Doorbell @ 2018-05-01T13:39:13.264407-04:00>>
2018-05-01 13:53:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.doorbell_alarm_type, old_state=<state sensor.doorbell_alarm_type=0; node_id=91, value_index=0, value_instance=1, value_id=72057595570700289, unit_of_measurement=, friendly_name=Doorbell Alarm Type @ 2018-05-01T13:53:02.620340-04:00>, new_state=<state sensor.doorbell_alarm_type=0; node_id=91, value_index=0, value_instance=1, value_id=72057595570700289, unit_of_measurement=, friendly_name=Doorbell Alarm Type @ 2018-05-01T13:53:04.729373-04:00>>
2018-05-01 13:53:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.doorbell_alarm_level, old_state=<state sensor.doorbell_alarm_level=0; node_id=91, value_index=1, value_instance=1, value_id=72057595570700305, unit_of_measurement=, friendly_name=Doorbell Alarm Level @ 2018-05-01T13:53:02.621490-04:00>, new_state=<state sensor.doorbell_alarm_level=0; node_id=91, value_index=1, value_instance=1, value_id=72057595570700305, unit_of_measurement=, friendly_name=Doorbell Alarm Level @ 2018-05-01T13:53:04.730349-04:00>>
2018-05-01 13:53:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.doorbell_sourcenodeid, old_state=<state sensor.doorbell_sourcenodeid=0; node_id=91, value_index=2, value_instance=1, value_id=72057595570700321, unit_of_measurement=, friendly_name=Doorbell SourceNodeId @ 2018-05-01T13:53:02.624282-04:00>, new_state=<state sensor.doorbell_sourcenodeid=0; node_id=91, value_index=2, value_instance=1, value_id=72057595570700321, unit_of_measurement=, friendly_name=Doorbell SourceNodeId @ 2018-05-01T13:53:04.733385-04:00>>
2018-05-01 13:53:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.doorbell_power_management, old_state=<state sensor.doorbell_power_management=1; node_id=91, value_index=11, value_instance=1, value_id=72057595570700465, unit_of_measurement=, friendly_name=Doorbell Power Management @ 2018-05-01T13:53:02.625546-04:00>, new_state=<state sensor.doorbell_power_management=0; node_id=91, value_index=11, value_instance=1, value_id=72057595570700465, unit_of_measurement=, friendly_name=Doorbell Power Management @ 2018-05-01T13:53:04.734073-04:00>>
any suggestions?
