Nexia Thermostat Problem in 2022.9.0 - Fixed
Edit to add: This is working again as of 2022.9.4. Thanks!
Since updating to HA Container v2022.9.0, I can no longer set the temperature on my Nexia/Trane XL824 from Home Assistant. I’m using the built-in Nexia integration. Here’s what the climate.thermostat entity looks like.
Thanks for any help!
2022-09-07_17-04-53
Are you seeing anything in your logs?
No. See debug logs for the climate and nexia entities below. Note that I can set the temp using the Climate: Set temperature service, but cannot set it through the UI climate entity card.
2022-09-07 22:43:22.633 INFO (SyncWorker_5) [homeassistant.loader] Loaded climate from homeassistant.components.climate
2022-09-07 22:43:22.777 INFO (MainThread) [homeassistant.setup] Setting up climate
2022-09-07 22:43:22.780 INFO (MainThread) [homeassistant.setup] Setup of domain climate took 0.0 seconds
2022-09-07 22:43:22.813 INFO (MainThread) [homeassistant.setup] Setting up nexia
2022-09-07 22:43:22.813 INFO (MainThread) [homeassistant.setup] Setup of domain nexia took 0.0 seconds
2022-09-07 22:43:22.843 INFO (MainThread) [homeassistant.components.climate] Setting up climate.mqtt
2022-09-07 22:43:22.901 DEBUG (MainThread) [nexia.home] POST: Calling url https://www.mynexia.com/mobile/accounts/sign_in with headers: {'X-AppVersion': '6.0.0', 'X-AssociatedBrand': 'nexia'} and payload: {'login': 'XXXXXX', 'password': 'XXXXXXXX', 'children': [], 'childSchemas': [], 'commitModel': None, 'nextHref': None, 'device_uuid': '3200cf7a-a417-49c4-8fe8-6e4d858099e3', 'device_name': 'Home', 'app_version': '6.0.0', 'is_commercial': False}
2022-09-07 22:43:25.114 DEBUG (MainThread) [nexia.home] POST: Response from url https://www.mynexia.com/mobile/accounts/sign_in: <StreamReader 157 bytes eof>
2022-09-07 22:43:25.114 DEBUG (MainThread) [nexia.home] POST: Calling url https://www.mynexia.com/mobile/session with headers: {'X-AppVersion': '6.0.0', 'X-AssociatedBrand': 'nexia', 'X-MobileId': '2766751', 'X-ApiKey': 'a2a615446a7b8b4cf2517887e24a3a31'} and payload: {'app_version': '6.0.0', 'device_uuid': '3200cf7a-a417-49c4-8fe8-6e4d858099e3'}
2022-09-07 22:43:25.444 DEBUG (MainThread) [nexia.home] POST: Response from url https://www.mynexia.com/mobile/session: <StreamReader 3159 bytes eof>
2022-09-07 22:43:25.445 DEBUG (MainThread) [nexia.home] GET: Calling url https://www.mynexia.com/mobile/houses/1382988
2022-09-07 22:43:25.729 DEBUG (MainThread) [nexia.home] GET: RESPONSE https://www.mynexia.com/mobile/houses/1382988: response.status 200
2022-09-07 22:43:25.730 DEBUG (MainThread) [nexia.thermostat] Updated thermostat_id:2622029 with new data from post
2022-09-07 22:43:25.730 DEBUG (MainThread) [nexia.zone] Updated thermostat_id:2622029 zone_id:83583161 with new data from post
2022-09-07 22:43:25.732 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.nexia
2022-09-07 22:43:25.733 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.nexia
2022-09-07 22:43:25.735 INFO (MainThread) [homeassistant.components.climate] Setting up climate.nexia
2022-09-07 22:43:25.736 INFO (MainThread) [homeassistant.components.scene] Setting up scene.nexia
2022-09-07 22:43:25.737 INFO (MainThread) [homeassistant.components.switch] Setting up switch.nexia
