Next alarm detected by phone - not by server
I am trying to automate the alarm clock. SO I activated the sensor “next alarm”
On the phone when I activate the sensor I can see the time of the next alarm (in utc time)
so I beieve the phone picked it up properly.
But on the server no corresponding entity is added to the device. So I do not see exactly how to use it.
Note: when activating this sensor a list called (in french) “authorize list” is provided. It is a huge list of application service, that may serve as clock . I did not check anything there because I do not know which one correspond to my clock (samsung phone). Is it compulsory to check anything there especially if the sensor reports the actual next alarm clock time? Could it be the reason why I do not get the sensor value over the server? In this case, since the application properly finds my alarm clock setting why doesn’t auto check the corresponding service in the list?
Thank you for your help
Ok. I changed the alarm time and now it is showing in HA
maybe it needded to be “re”-set once to trigger the first “detection”
