An adjusted version to allow two phones with alarm and filter during morning hours and only act when home.
[{"id":"b0d50eaa.d005a","type":"inject","z":"56bc8fc0.48d1d","name":"Time","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"*/1 0-23 * * *","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":290,"y":900,"wires":[["547c2851.78a08"]]},{"id":"b41ed2da.23b9c8","type":"api-current-state","z":"56bc8fc0.48d1d","name":"Guy","server":"9c0d279b.e09278","version":2,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.gsm_guy_next_alarm","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":430,"y":980,"wires":[["ac7475ed.139358"]]},{"id":"cd3f36cf.c369c","type":"switch","z":"56bc8fc0.48d1d","name":"","property":"timestamp","propertyType":"msg","rules":[{"t":"eq","v":"alarm","vt":"msg"},{"t":"eq","v":"alarmlut","vt":"msg"}],"checkall":"true","repair":false,"outputs":2,"x":770,"y":900,"wires":[["43c0ec2f.76874c"],["43c0ec2f.76874c"]]},{"id":"9997dd82.31229","type":"debug","z":"56bc8fc0.48d1d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":750,"y":1060,"wires":[]},{"id":"ac7475ed.139358","type":"moment","z":"56bc8fc0.48d1d","name":"Format","topic":"","input":"","inputType":"msg","inTz":"Europe/Brussels","adjAmount":0,"adjType":"days","adjDir":"add","format":"YY-MM-DD HH:mm","locale":"C","output":"alarm","outputType":"msg","outTz":"Europe/Brussels","x":580,"y":980,"wires":[["98fc39db.7d2ea8"]]},{"id":"547c2851.78a08","type":"moment","z":"56bc8fc0.48d1d","name":"Format","topic":"","input":"","inputType":"msg","inTz":"Europe/Brussels","adjAmount":0,"adjType":"days","adjDir":"add","format":"YY-MM-DD HH:mm","locale":"C","output":"timestamp","outputType":"msg","outTz":"Europe/Brussels","x":440,"y":900,"wires":[["b41ed2da.23b9c8"]]},{"id":"98fc39db.7d2ea8","type":"api-current-state","z":"56bc8fc0.48d1d","name":"Lut","server":"9c0d279b.e09278","version":2,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.gsm_lut_next_alarm","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":430,"y":1060,"wires":[["7e95b7e6.69e838"]]},{"id":"7e95b7e6.69e838","type":"moment","z":"56bc8fc0.48d1d","name":"Format","topic":"","input":"","inputType":"msg","inTz":"Europe/Brussels","adjAmount":0,"adjType":"days","adjDir":"add","format":"YY-MM-DD HH:mm","locale":"C","output":"alarmlut","outputType":"msg","outTz":"Europe/Brussels","x":580,"y":1060,"wires":[["cd3f36cf.c369c","9997dd82.31229"]]},{"id":"43c0ec2f.76874c","type":"time-range-switch","z":"56bc8fc0.48d1d","name":"Is Ochtend?","lat":"","lon":"","startTime":"4:00","endTime":"9:00","startOffset":0,"endOffset":0,"x":950,"y":900,"wires":[["ba135132.b83e4"],[]]},{"id":"ba135132.b83e4","type":"api-current-state","z":"56bc8fc0.48d1d","name":"Thuis","server":"9c0d279b.e09278","version":2,"outputs":2,"halt_if":"home","halt_if_type":"str","halt_if_compare":"is","entity_id":"group.household","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1130,"y":900,"wires":[["5e7c9d90.b4a1b4"],[]]},{"id":"5e7c9d90.b4a1b4","type":"api-call-service","z":"56bc8fc0.48d1d","name":"Rollen omhoog","server":"9c0d279b.e09278","version":3,"debugenabled":false,"service_domain":"cover","service":"open_cover","entityId":"cover.rol_lutguy, cover.rol_dressing","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1300,"y":900,"wires":[[]]},{"id":"9c0d279b.e09278","type":"server","name":"Home Assistant","addon":true}]
