But it looks like Voice is going to stay a black box. We can see all sorts of events and errors in the Assist debug log, but we canāt actually use any of them. Itās a bit of a deal breaker.
Great work from the team!
Is there any update on voice matching please? All the new stuff youāre adding is great, but voice matching is a must-have for me living in a family where everyone wants to listen to their own music on their own accounts. I canāt move away from Google until Voice/Assist supports this.
Many thanks
Great updates! Hopefully we can get a timer entity when one is set so we can display it on the dashboard
Yes, thanks! Iāve got 8 models currently in ātrialā modeāaiming to narrow it down to one, though I might land on three depending on the context. Iām offloading to a 3090 GPU running Whisper and Piper on Proxmox. So far, Iām leaning towards Qwen, Llama, Phi, and Mistral. Iāll check out Fridayās partyāI mustāve missed the invite on that.
Yes, we need the whole Timers integration! ![]()
and Alarm clock integration too ![]()
Thatās why it helps to read the docs ![]()
The UI will almost certainly never show all the possible options available in yaml, especially when it comes to cards. Might as well go direct to the source to see what you can do
You can do that already with a custom sentence/intent.
So happy to see voice development continue. Canāt wait to try a few things.
Well done team!
+1 that assist debug logging would be nice to be able to enable for troubleshooting voice and LLM commands.
ESPhome has functionality to transmit events from any stage of VA to Home Assistant. Just configure it to suit your needs.
I used this to get text from stt. But after adding āAsk a question,ā it was no longer necessary.
But as I understand it, thatās thanks to ESPhome, not Home Assistant.
Also - and this may come as a shock - not all of us use ESPhome. ![]()
That page you linked mentions HA as a prerequisite for ESphomes Voice Assistant stuff. And anyone that uses Voice Assistant Preview Edition, uses ESPHome.
But not everyone uses Voice Assistant Preview Edition and Open Voice is more than VPE.
In fact, Assist predates VPE by quite a long way. It has never allowed users to leverage events and errors - and there are plenty of them:
stage: done
run:
pipeline: 01h0amejr3nf5059gavrx5jm7g
language: en
conversation_id: 01JZ86PBWFHMAPA1Q6W0EVMCQN
runner_data:
stt_binary_handler_id: null
timeout: 300
events:
- type: run-start
language: en
runner_data:
timeout: 300
timestamp: "2025-07-03T13:12:54.927548+00:00"
- type: intent-start
engine: conversation.home_assistant
language: en
intent_input: undo the trittle.
device_id: null
prefer_local_intents: false
timestamp: "2025-07-03T13:12:54.927637+00:00"
- type: intent-end
processed_locally: true
intent_output:
response:
speech:
plain:
speech: No area named undo
extra_data: null
card: {}
language: en
response_type: error
code: no_valid_targets
continue_conversation: false
timestamp: "2025-07-03T13:12:55.155924+00:00"
- type: run-end
data: null
timestamp: "2025-07-03T13:12:55.155987+00:00"
intent:
language: en
device_id: null
done: true
intent_output:
response:
speech:
plain:
extra_data: null
card: {}
language: en
This appears to have been an early design decision.
When it comes to follow-up on missing parameters, it would be cool if we could set some defaults. For example, āOk Nabu, dim the lights in the living room.ā
In a separate place, maybe we could define some rules for how it would determine the amount. Iām not a programmer, but perhaps something like this:
defaults:
lights:
- light.living_room_pot_lights
- brightness:
- if (input_boolean.party_mode == on && command == dim) # allow for 'dim' vs 'brighten' type commands
set to 20%
- elif (input_select.home_mode == 'day' && light.living_room_pot_light.brightness > 75%)
change by 25% # allow for 'change by' commands (if dim was requested, it will go down by 25%, if brighten was requested, up by 25%
- elif (input_select.home_mode == 'day' && light.living_room_pot_lights > 40%)
set to 35% # allow for 'set to' commands
- elif ...
- else: ask # allow for ask command, that will ask for confirmation everytime.
timers:
- timer.washing_machine # if a timer is set with the tag washing machine
0:45:00 # eg. Ok Nabu, set my washing machine timer
- timer.dryer
1:00:00
- timer.kitchen.device # add some defaults on a per device level?
ask # eg. When using the kitchen speaker, always ask
Again, this sort of thing can be done with intent scripts.
Agree at least with feentrant scripts and event triggers you can In theory both have a script call out and ask for clarification if said info isnāt in (condition X) and we can now ask a question and receive answers with clarified slots. You could then restart the script with the correct data which would skip the question etcā¦
Workflow Ala HA voice.
