Nextcloud integration: nextcloud_storage_num_files
I wonder, if someone uses the nextcloud integration.
When I have a look at the nextcloud_storage_num_files sensor, it reports a much bigger number than a linux file count (ls -FR data | grep -v / | wc -l) in the nextcloud base directory.
Any ideas what this sensor reports?
you’re lucky… tried to let it work in general for weeks without success… Give it up…
Every time got error that integration was not correct
The integration itself was setup straight forward. But the sensors…
From my point of view most of them are not very useful… Maybe except the num_shares-group.
I tried a bit with some sql and command line sensors. Maybe that’s something:
#=== Monitoring Nextcloud
- platform: sql
  db_url: !secret nextcloud_db_url
  scan_interval: 3600              # Aktualisieren jede Stunde
  queries:
    - name: 'Nextcloud Database size'
      query: 'SELECT table_schema "ncdb", Round(Sum(data_length + index_length) / 1048576, 0) "value" FROM information_schema.tables WHERE table_schema="ncdb" GROUP BY table_schema;'
      column: 'value'
      unit_of_measurement: MB
- platform: command_line
  name: Nextcloud Files Size
  command: "du -ms /nextcloud/userid/files | cut -f1"
  unit_of_measurement: 'GB'
  value_template: '{{ (value | float) / 1024 }}'
  command: "ls -aFR /nextcloud/userid/files | grep -v / | grep -v ^$ | wc -l"
  value_template: '{{ value | int }}'
  scan_interval: 43200             # Aktualisieren 2 mal am Tag
  name: Nextcloud Thumbnails Size
  command: "du -ms /nextcloud/appdata_xyz4711/preview | cut -f1"
  command_timeout: 30
  command: "ls -aFR /nextcloud/appdata_xyz4711/preview | grep -v / | grep -v ^$ | wc -l"
  command_timeout: 30
Good inspirations. I´m currently thinking of making a “Nextcloud update available” sensor and I have two ideas for that - but that´s another topic.
For me the nextcloud_storage_num_files is working from the beginning. Only had some struggles after a NC version update, but according to Number of files missing · Issue #314 · nextcloud/serverinfo · GitHub there´s a workaround for that.
