NextDNS Integration being ignored?
Hi - I’ve added the NextDNS Integration, added my API, and created a new profile so I can see all the DNS traffic from HASS. The set up all very went smoothly, but all my DNS traffic is still routing via my generic profile that is configured on my home router. I assume the HASS intergration being ignored, but don’t know how to fault find any further. I restarted and searched system logs for ‘dns’ but zero hits.
I’m running HASS on Rpi. Also running TailScale but switching it off makes no difference.
NextDNS integration shows statistics and allows configuration of a NextDNS profile. Integration does not cause the HA server to use this NextDNS profile.
Thank you for the answer. Is it possible to configure it so it uses NextDNS, either in HASS or Rpi network settings?
Yes, you can set the DNS servers you want in the network settings of your device.
